aberniando
Just a quick question here. I hope someone here have ever try to do recording with Alder Lake QuickSync in 1440p 60fps. How is it going? Is it fast enough to get the job done? Thanks
thanks!! uhd 730 or 770??I did some testing for ya. Streaming 4k & 720p @ 60fps concurrently using QuickSync. All good over here so far....
if you don't mind, try recording 1440p or 4K @ 60 fps with UHD 770 instead of live streaming. of course with higher bitrate (simple setting -> Indistinguishable quality maybe??)770
Also tested UHD P630 that is on a Xeon I have & that worked just as well.
This thread gave me a reason to enable QuickSync on my Z690. Thx for posting it!
building. just to record my gameplay in 1440p at least. and it would be a dedicated pc. I play my games on console. so yea, my UHD730 would be able to focus only for encoding. Is it gonna work?R U buying/building a PC?
I would highly recommend that you not depend solely on the 770. Get a PCI-e card too, let it do all the work & only use the 770 for encoding.
I'm testing my multicast now using the 3090 for 4k encoding duties & the 770 for streaming 1080p & 720p. An hour & half in, everything is purring like a kitten & the 770 is only 15% utilized.
Video | |
| ID : | 1 |
| Format : | AVC |
| Format/Info : | Advanced Video Codec |
| Format profile : | [email protected] |
| Format settings : | CABAC / 3 Ref Frames |
| Format settings, CABAC : | Yes |
| Format settings, Reference frames : | 3 frames |
| Codec ID : | V_MPEG4/ISO/AVC |
| Duration : | 9 min 0 s |
| Width : | 3 840 pixels |
| Height : | 2 160 pixels |
| Display aspect ratio : | 16:9 |
| Frame rate mode : | Constant |
| Frame rate : | 60.000 FPS |
| Color space : | YUV |
| Chroma subsampling : | 4:2:0 |
| Bit depth : | 8 bits |
| Scan type : | Progressive |
| Default : | Yes |
| Forced : | No |
| Color range : | Limited |
| Color primaries : | BT.709 |
| Transfer characteristics : | BT.709 |
| Matrix coefficients : | BT.709 |
