Application Audio Capture: Capture active window only
BlueisDue
Is it possible to define the Application Audio Capture (BETA) source as the currently selected window?
For context, I am using this as an effective way to isolate game audio from my microphone / discord, and then rebalancing audio levels in post prod.
This set up works excellently, however the sole issue I have is that I have to manually define the window name everytime I change which game I am playing, e.g. destiny2.exe as per below:
I have tried using the other options under "Window Match Priority" with no success.
Is it at all possible to define the Window as the currently active window, So that I no longer have to manually configure this source everytime I switch to a different .exe?
