Blurry stream when moving in game (TWITCH)
Stfiler
Hi, I need you to help me with a problem that I am having in my streams. This is that they look blurry / pixelated when I move in the game and when I am still it looks perfect. I don't understand the reason, because my download and upload speeds are good.
Below I leave screenshots of my settings and my speed
My PC Settings :
GPU: GTX 1080
CPU: i5 7600K
RAM: 24GB
Sorry for my English. Thanks so much for reading
1. Run OBS as Admin
2. Your GPU is maxed out and OBS can't render scenes fast enough. Running a game without vertical sync or a frame rate limiter will frequently cause performance issues with OBS because your GPU will be maxed out. OBS requires a little GPU to render your scene.
Enable Vsync or set a reasonable frame rate limit that your GPU can handle without hitting 100% usage.
If that's not enough you may also need to turn down some of the video quality options in the game. If you are experiencing issues in general while using OBS, your GPU may be overloaded for the settings you are trying to use.
Please check our guide for ideas why this may be happening, and steps you can take to correct it: GPU Overload Issues.
Uncheck Psycho Visual Tuning.
3. The encoder is skipping frames because of CPU overload. Read about General Performance and Encoding Issues.
4. Having the YUV Color range set to "Full" will cause playback issues in certain browsers and on various video platforms. Shadows, highlights and color will look off. In OBS, go to "Settings -> Advanced" and set "YUV Color Range" back to "Partial".
