Browser source issues
endypearl
I had a lot of OBS issues today as it kept crashing due to plug-ins from streamlabs, I ended up having to go back to version 30.2.3. Now, however, none of my browser sources seem to work. The program is no longer crashing and I uninstalled all of the plugins and even streamlabs off of my computer, thinking that was the issue. Nope. The crashing has stopped since, but my fugitech and any browser source i try isn't showing up (it registers but nothing shows up on my screen or in recordings, you can only see and empty red square). I have tested everything and the only thing that seems to maybe be the issue is my OBS. Weirdly enough, the exact same configuration seems to work fine on my laptop. So my discord, fugitech and browsers aren't the issue. I have restarted my pc 3 times and shut it down fully and started it up again multiple times as well. I deleted and reinstalled everything and its not working. Is there something I'm missing. https://obsproject.com/logs/flCKijSKaYH2BQzA
After removing stramlabs plugin you have to uninstall OBS and then reinstall it in order to fix some changes this plugin perform.
Do not set display capture and game / window capture on the same scene because display capture causes interferences with the other two methods.
Your iGPU is too old (the CPU is really old). Probably your system can't be used to record anything above 720p at 30fps
