No
Here's the file info from Vegas Pro for a recording I did Friday night:
General
Folder: K:\2020-09-04 DSO, Roseland Waterpark Drive-In, Canandaigua, NY 1080p H265
Type: HEVC
Size: 9.33 GB (9,552,327,878 bytes)
Created: Friday, September 4, 2020, 6:00:56 PM
Modified: Friday, September 4, 2020, 7:26:02 PM
Accessed: Friday, September 4, 2020, 7:26:02 PM
Attributes: Archive
Streams
Video: 01:25:05.200, 60.000 fps progressive, 1920x1080x32, HEVC
Audio: 01:25:05.813, 48,000 Hz, Stereo, PCM
Summary
[TCFM]: 7
ACID information
ACID chunk: no
Stretch chunk: no
Stretch list: no
Stretch info2: no
Beat markers: no
Detected beats: no
Other metadata
Regions/markers: no
Command markers: no
Media manager
Media tags: no
Plug-In
Folder: C:\Program Files\VEGAS\VEGAS Pro 17.0\FileIO Plug-Ins\so4compoundplug
Format: AVC
Version: Version 1.0 (Build 8532)
Company: MAGIX Computer Products Intl. Co.
MediaTab Info:
===================== General =====================
Count : 322
Countof stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Countof video streams : 1
Countof audio streams : 1
Video formats : HEVC
Video_Format_WithHint_List : HEVC
Codecs Video : HEVC
Audio formats : PCM
Audio_Format_WithHint_List : PCM
Audio codecs : PCM
Complete name : K:\2020-09-04 DSO, Roseland Waterpark Drive-In, Canandaigua, NY 1080p H265\dso2020-09-04_s1_18-00-55_1080p_H265_PCM_Master.mov
Folder name : K:\2020-09-04 DSO, Roseland Waterpark Drive-In, Canandaigua, NY 1080p H265
File name : dso2020-09-04_s1_18-00-55_1080p_H265_PCM_Master
File extension : mov
Format : MPEG-4
Format : MPEG-4
Format extensionsusually us : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
Commercial name : MPEG-4
Formatprofile : QuickTime
Internet media type : video/mp4
Codec Id : qt
Codec Id : qt 0000.02 (qt )
Codec URL :
http://www.apple.com/quicktime/download/standalone.html
CodecID_Version : 0000.02
CodecID_Compatible : qt
Codec : MPEG-4
Codec : MPEG-4
Codec extensionsusually use : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
File size : 9552327878
File size : 8.90 GB
File size : 9 GB
File size : 8.9 GB
File size : 8.90 GB
File size : 8.896 GB
Duration (ms) : 5105814
Duration (ms) : 1h 25mn
Duration (ms) : 1h 25mn 5s 814ms
Duration (ms) : 01:25:05.814
Duration (ms) : 01:25:05:13
Duration (ms) : 01:25:05.814 (01:25:05:13)
Overall bit rate : 14966981
Overall bit rate : 15.0 Mbps
Frame rate : 60.000
Frame rate : 60.000 fps
Frame count : 306313
Stream size : 8328272
Stream size : 7.94 MB (0%)
Stream size : 8 MB
Stream size : 7.9 MB
Stream size : 7.942 MB
Proportion of this stream : 0.00087
HeaderSize : 20
DataSize : 9543999622
FooterSize : 8328236
IsStreamable : No
File creation date : UTC 2020-09-04 22:00:56.162
File creation date (local) : 2020-09-04 18:00:56.162
File last modification date : UTC 2020-09-04 23:26:02.161
File last modification date : 2020-09-04 19:26:02.161
Writing application : Lavf58.29.100
===================== Video =====================
Count : 334
Kind of stream : Video
StreamOrder : 0
Format : HEVC
Format info : High Efficiency Video Coding
Format URL :
http://www.itu.int
Commercial name : HEVC
Formatprofile :
[email protected]@Main
Internet media type : video/H265
Codec Id : hev1
Codec info : High Efficiency Video Coding
Codec URL :
http://www.itu.int/
Codec : HEVC
Codec : HEVC
Codec/cc : hev1
Codecprofile :
Duration (ms) : 5105217
Duration (ms) : 1h 25mn 5s 217ms
Duration (ms) : 01:25:05.217
Duration (ms) : 01:25:05.217 (01:25:05:13)
Bit rate : 12651413
Bit rate : 12.7 Mbps
Width : 1920
Width : 1 920 pixels
Height : 1080
Height : 1 080 pixels
Stored_Height : 1088
Sampled_Width : 1920
Sampled_Height : 1080
Pixel aspect ratio : 1.000
Display aspect ratio : 1.778
Display aspect ratio : 16:9
Rotation : 0.000
Frame rate mode : CFR
Frame rate mode : Constant
Frame rate : 60.000
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.102
Stream size : 8073525366
Stream size : 7.52 GB (85%)
Stream size : 8 GB
Stream size : 7.5 GB
Stream size : 7.519 GB
Proportion of this stream : 0.84519
Color range : Limited
colour_description_present : Yes
Matrix coefficients : BT.709
===================== Audio =====================
Count : 272
Kind of stream : Audio
StreamOrder : 1
Format : PCM
Commercial name : PCM
Formatsettings : Little / Signed
Formatsettings, Endianness : Little
Formatsettings, Sign : Signed
Codec Id : in24
Codec URL :
Codec : PCM
Codec : PCM
Codec family : PCM
Codec URL :
Codec/cc : in24
Codecsettings : Little / Signed
Codecsettings, Endianness : Little
Codecsettings, Sign : Signed
Bit rate mode : CBR
Bit rate mode : Constant
Bit rate : 2304000
Bit rate : 2 304 Kbps
Channel(s) : 2
Channel(s) : 2 channels
Channel positions : Front: L R
ChannelLayout : L R
Sampling rate : 48000
Sampling rate : 48.0 KHz
Samples count : 245079072
Resolution : 24
Resolution : 24 bits
Bit depth : 24
Bit depth : 24 bits
Stream size : 1470474240
Stream size : 1.37 GB (15%)
Stream size : 1 GB
Stream size : 1.4 GB
Stream size : 1.369 GB
Proportion of this stream : 0.15394
Default : Yes
Default : Yes
Alternate group : 1
Alternate group : 1
