Bug Report Can't decode DTS?
DiGG
Member
When choosing 'Media Source', and selecting a file with DTS audio, the screen just stays black and nothing is playing. Selecting 'Use hardware decoding when available' doesn't change anything. On the other hand it decodes AC3 without problems.
Something you guys know about, and will fix in the future?
It's very possible. Not may people have tried using OBS Multiplatform for Windows yet, and even fewer have tried using the media source to play back less common formats.
Can you post your log, and maybe an example file for us to test with?
Show me a screenshot that it works, cuz it doesn't for me! Are there special decoders I need to install or something?
Me loading the file:
This is how it looks when it's loaded:
This is how it looks transformed to "Fit to screen":
Nothing plays.
Well I get that line too. But after it you can see that the file got loaded.
Code:
21:27:14: source 'Media Source' (ffmpeg_source) created
21:27:14: unable to find input format
21:27:26: Input #0, matroska,webm, from 'C:/Users/Ace/Desktop/Cinderella.34 secs.intro.mkv':
21:27:26:   Metadata:
21:27:26:     encoder         :
21:27:26: libebml v1.3.1 + libmatroska v1.4.2
21:27:26:
21:27:26:     creation_time   :
21:27:26: 2015-07-03 03:08:17
21:27:26:
21:27:26:   Duration:
21:27:26: 00:00:34.75
21:27:26: , start:
21:27:26: 0.000000
21:27:26: , bitrate:
21:27:26: 8182 kb/s
21:27:26:
21:27:26:     Stream #0:0
21:27:26: (eng)
21:27:26: : Video: h264 (High), yuv420p, 1280x536
21:27:26: , SAR 1:1 DAR 160:67
21:27:26: ,
21:27:26: 23.98 fps,
21:27:26: 23.98 tbr,
21:27:26: 1k tbn,
21:27:26: 47.95 tbc
21:27:26:  (default)
21:27:26:
21:27:26:     Metadata:
21:27:26:       BPS             :
21:27:26: 6671734
21:27:26:
21:27:26:       BPS-eng         :
21:27:26: 6671734
21:27:26:
21:27:26:       DURATION        :
21:27:26: 00:00:34.743000000
21:27:26:
21:27:26:       DURATION-eng    :
21:27:26:
21:27:26:       NUMBER_OF_FRAMES:
21:27:26: 833
21:27:26:
21:27:26:       NUMBER_OF_FRAMES-eng:
21:27:26: 833
21:27:26:
21:27:26:       NUMBER_OF_BYTES :
21:27:26: 28974508
21:27:26:
21:27:26:       NUMBER_OF_BYTES-eng:
21:27:26: 28974508
21:27:26:
21:27:26:       _STATISTICS_WRITING_APP:
21:27:26: mkvmerge v7.5.0 ('Glass Culture') 64bit built on Jan  4 2015 16:48:44
21:27:26:
21:27:26:       _STATISTICS_WRITING_APP-eng:
21:27:26:
21:27:26:       _STATISTICS_WRITING_DATE_UTC:
21:27:26:
21:27:26:       _STATISTICS_WRITING_DATE_UTC-eng:
21:27:26:
21:27:26:       _STATISTICS_TAGS:
21:27:26: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
21:27:26:
21:27:26:       _STATISTICS_TAGS-eng:
21:27:26:
21:27:26:     Stream #0:1
21:27:26: (eng)
21:27:26: : Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s
21:27:26:  (default)
21:27:26:
21:27:26:     Metadata:
21:27:26:       BPS             :
21:27:26: 1508956
21:27:26:
21:27:26:       BPS-eng         :
21:27:26: 1508956
21:27:26:
21:27:26: 00:00:34.753000000
21:27:26:
21:27:26:
21:27:26: 3258
21:27:26:
21:27:26: 3258
21:27:26:
21:27:26: 6555096
21:27:26:
21:27:26: 6555096
21:27:26:
21:27:26:
21:27:26:
21:27:26:
21:27:26:
21:27:26:
21:27:26:
I tried installing ac3filter_2_6_0b.exe, made no changes. Tried installing LAVFilters-0.65-Installer.exe, made no changes. And tried installing FFDShow to no results too. Not sure if MatroskaSplitter.exe is needed (guess it is not), installed or not it makes no difference.
I'm lost. I reinstalled Windows 7 64bits two weeks ago, it's pretty much a clean slate here...
Admin or moderators, got any ideas what I should do? Must I reinstall Windows 7 altogether? (please remember it's only with DTS audio that it doesn't work, everything else works as it should)
I don't know. I downloaded that file and it actually didn't work for me either, and there didn't seem to be anything interesting in the log. I'll see if the person who made the plugin has any ideas.
Small update: when I tried to play back the file in 0.10.1, my logs showed no indication that the file was loading. But in the latest nightly build, I do indeed get indications in the log that the file is being read correctly. However, it is still not playing back. I'm continuing to look into it.
Also worth noting: when I try to play it back in VLC, it plays, but is super glitchy. Playback is not smooth at all. Are we sure the file itself doesn't have an issue?
