ItzayHR New Member Nov 8, 2022 #1 Nothing can be done at all. The moment I open OBS I get an error. Attachments Crash 2022-11-07 20-32-47.txt Crash 2022-11-07 20-32-47.txt 150 KB · Views: 90
FranckB Member Nov 8, 2022 #2 do you have any plugins? if so, uninstall OBS, delete the installation folder and that of AppData>Roaming>obs-studio Then reinstall OBS 28.1.2
PaiSand Active Member Nov 8, 2022 #3 ItzayHR said: Nothing can be done at all. The moment I open OBS I get an error. Click to expand... Have you updated the GPU drivers?
ItzayHR New Member Nov 9, 2022 #4 PaiSand said: Have you updated the GPU drivers? Click to expand... Yes
ItzayHR New Member Nov 9, 2022 #5 FranckB said: do you have any plugins? if so, uninstall OBS, delete the installation folder and that of AppData>Roaming>obs-studio Then reinstall OBS 28.1.2 Click to expand... Yes, i have plugins What is the problem with plugins? Because I have them since long before the problems.
FranckB Member Nov 9, 2022 #6 It is likely that your plug-ins do not work for version 28, check on the publisher's website and upgrade windows 10 to 22H2
