Disconnected once succesfully reconnected
Couin
Hi friends,
I use OBS 29.1.3 (64 bits) on Windows.
Based on https://www.digitalocean.com/commun...aming-server-using-nginx-rtmp-on-ubuntu-20-04 , I would build a nginx based rtmp server.
First, I tested on a VirtualBox machine, and I can connect successfully and stream, and play with VLC, and also use m3u8 URL to play stream in a webbrowser.
I used another stat.xsl as well as the procedure from Digital Ocean is wrong on this point.
So I can also vu rtmp server stat (I see the stream name when connected).
So, I'm testing on an OVH's VPS, I did the same rtmp server installation. I can see the rtmp statitics. But when I try to connect with OBS, I get a first notice "Disconnected, reconnect in 2 seconds", then "Reconnection successful" and directly "Disconnected, reconnect in 2 seconds", in loop (for each attempts).
But I don't know why.
Is there some logs anywhere in OBS, so I could get perhaps the reason of disconnection ?
Couin
Hi again,
Stupid duck , I forgot to change Allow publish for All...
Sorry (but I still interested for any log location, for a future experience).
