Here's the log. I just redownloaded and reinstalled the OBS 29.1.0-beta1 as well as your newest droidcam plugin...@lcalder seems to work OK for me, could you please upload and paste the OBS logs from your beta. If you would prefer not to post the logs publicly, send the link to [email protected]
Just saw this... And yes it looks like the plugin isn't loading fully. I am not sure why at the moment, lets see if there are any other similar reports. So far it works fine for myself and others, so this could be specific to your setup and we would need to debug further .Here's the log. I just redownloaded and reinstalled the OBS 29.1.0-beta1 as well as your newest droidcam plugin...
Thanks for the plugin. I have the pro version and love it.
I am having the same issue myself using Droidcam OBS using the latest OBS beta, 29.1 beta 2. The plugin was working before updating to the beta version of OBS. Tried uninstalling Droidcam OBS and then reinstalling the latest version of the plugin, but that didn't help fix the issue. Here's a log of my instance of OBS where the plugin failed to load.Just saw this... And yes it looks like the plugin isn't loading fully. I am not sure why at the moment, lets see if there are any other similar reports. So far it works fine for myself and others, so this could be specific to your setup and we would need to debug further .
Module '../../obs-plugins/64bit/droidcam-obs.dll' not loaded`
I installed v2.0.1 and the plugin still does not load. I installed the v29 beta through the installer, but I have also tried using the zip version and get the same error. Tried also removing the source from my scenes in OBS as PaiSand suggested, but this also did not fix the issue. I still see the same [Module '../../obs-plugins/64bit/droidcam-obs.dll' not loaded] error in the log files.Unfortunately as per the logs,
@lesstech64 can you install v2.0.1 and see if it loads?
Edit: and can you tell us how you got the v29 beta? Was is through the installer, or the zip?
This release adds support for OBS Studio version 29.1 (currently in beta).
*macOS and Linux packages are still pending.
