FIX Crackling, Popping Chirping Sound IF Motu M2 M4 USB Audio Interface
maxotics
I found I needed to changed the buffer size on my Motu M4 Audio Interface (windows service), from DEFAULT 256 Buffer Size to 64, otherwise I had bad audio from Voicemod, pulling from UBS interface, into OBS. Although this tip is buried in other posts, I'm putting this here to make it easy to find.
The problem came back. However, I could fix it by either setting the MOTU interface to work as a general Mic/Aux input, or to create another "Audio Input Capture" Source and attach that to MOTU. So it seems to me a source can get corrupted, or something change, that will create a problem where it cuts out every 30 seconds. Please let us know if you have this problem too and if this corrects it.
