GAME CAPTURE ONLY HAS AUDIO NO VIDEO
connorjones
I have been trying to use OBS for game capture with retro consoles, specifically gamecube and ps2. I am able to get audio through OBS just fine, but there's no video, just a blank screen. Has anyone else encountered this issue?
I have tried two different capture cards and both had the same problem, so I feel like it must be an issue in OBS. I have been using video capture device, and while OBS clearly recognizes the AV to USB 2.0 for both capture cards, I still can't figure out how to get the video going. I did change the graphic settings to high performance but it didn't seem to make a difference.
If anyone can give recommendations on a better setup for this sort of thing, or if anyone knows a solution to this issue, I would greatly appreciate the help.
Log: https://obsproject.com/logs/dATnKBXFi8tN9lcK
check windows kamera privancy settings
have tried my AV 2 USB and it Works good have you triede more than one source ?
