Question / Help Heyo i can't record with my GPU
Herrknick
My log file :L
11:40:20.912: CPU Name: AMD Ryzen 7 1700X Eight-Core Processor
11:40:20.912: CPU Speed: 3600MHz
11:40:20.912: Physical Cores: 8, Logical Cores: 16
11:40:20.912: Physical Memory: 16311MB Total, 13799MB Free
11:40:20.912: Windows Version: 10.0 Build 17134 (revision: 112; 64-bit)
11:40:20.912: Running as administrator: false
11:40:20.912: Aero is Enabled (Aero is always on for windows 8 and above)
11:40:20.913: Windows 10 Gaming Features:
11:40:20.913: Game DVR: On
11:40:20.918: Sec. Software Status:
11:40:20.920: Windows Defender Antivirus: enabled (AV)
11:40:20.920: Windows-Firewall: enabled (FW)
11:40:20.921: Windows Defender Antivirus: enabled (ASW)
11:40:20.921: Portable mode: false
11:40:21.028: OBS 21.1.2 (64bit, windows)
11:40:21.028: ---------------------------------
11:40:21.028: audio settings reset:
11:40:21.028: samples per sec: 48000
11:40:21.028: speakers: 1
11:40:21.030: ---------------------------------
11:40:21.030: Initializing D3D11...
11:40:21.030: Available Video Adapters:
11:40:21.032: Adapter 1: NVIDIA GeForce GTX 1050 Ti
11:40:21.032: Dedicated VRAM: 4213178368
11:40:21.032: Shared VRAM: 4257155072
11:40:21.032: output 1: pos={0, 0}, size={1920, 1080}, attached=true
11:40:21.041: Loading up D3D11 on adapter NVIDIA GeForce GTX 1050 Ti (0)
11:40:21.801: D3D11 loaded successfully, feature level used: 45056
11:40:22.491: ---------------------------------
11:40:22.491: video settings reset:
11:40:22.491: base resolution: 1920x1080
11:40:22.491: output resolution: 1280x720
11:40:22.491: downscale filter: Bicubic
11:40:22.491: fps: 60/1
11:40:22.491: format: NV12
11:40:22.491: YUV mode: 601/Partial
11:40:22.493: Audio monitoring device:
11:40:22.493: name: Standard
11:40:22.493: id: default
11:40:22.493: ---------------------------------
11:40:22.495: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
11:40:22.499: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
11:40:22.722: [AMF] AMF Test failed due to one or more errors.
11:40:22.722: Failed to initialize module 'enc-amf.dll'
11:40:22.766: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
11:40:22.767: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
11:40:22.767: (127)
11:40:22.767: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
11:40:22.768: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
11:40:22.770: [browser_source: 'Version: 1.31.0']
11:40:22.778: NVENC supported
11:40:23.340: Couldn't find VLC installation, VLC video source disabled
11:40:23.463: No blackmagic support
11:40:23.487: ---------------------------------
11:40:23.487: Loaded Modules:
11:40:23.487: win-wasapi.dll
11:40:23.487: win-mf.dll
11:40:23.487: win-dshow.dll
11:40:23.487: win-decklink.dll
11:40:23.487: win-capture.dll
11:40:23.487: vlc-video.dll
11:40:23.487: text-freetype2.dll
11:40:23.487: rtmp-services.dll
11:40:23.487: obs-x264.dll
11:40:23.487: obs-vst.dll
11:40:23.487: obs-transitions.dll
11:40:23.487: obs-text.dll
11:40:23.487: obs-qsv11.dll
11:40:23.487: obs-outputs.dll
11:40:23.487: obs-filters.dll
11:40:23.487: obs-ffmpeg.dll
11:40:23.487: obs-browser.dll
11:40:23.487: image-source.dll
11:40:23.487: frontend-tools.dll
11:40:23.487: enc-amf.dll
11:40:23.487: coreaudio-encoder.dll
11:40:23.487: ==== Startup complete ===============================================
11:40:23.573: All scene data cleared
11:40:23.573: ------------------------------------------------
11:40:23.605: WASAPI: Device 'Line (Steinberg UR12 )' initialized
11:40:23.675: warning: deprecated pixel format used, make sure you did set range correctly
11:40:23.678: [WASAPISource::WASAPISource] Device '{0.0.0.00000000}.{6810f68a-9cfd-4964-b990-b3c13cb617fb}' not found. Waiting for device
11:40:23.679: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds
11:40:24.609: Switched to scene 'player'
11:40:24.615: ------------------------------------------------
11:40:24.615: Loaded scenes:
11:40:24.615: - scene 'SzFacecam':
11:40:24.615: - source: 'Videoaufnahmegerät 3' (dshow_input)
11:40:24.615: - source: 'Bild 6' (image_source)
11:40:24.615: - source: 'cam' (dshow_input)
11:40:24.615: - filter: 'Chroma Key' (chroma_key_filter)
11:40:24.615: - filter: 'Zuschneiden/Pad' (crop_filter)
11:40:24.615: - source: 'BrowserSource' (browser_source)
11:40:24.615: - source: 'top don' (browser_source)
11:40:24.615: - source: 'Bild 5' (image_source)
11:40:24.615: - source: 'loots' (browser_source)
11:40:24.615: - scene 'Lol Client':
11:40:24.615: - source: 'overlay' (image_source)
11:40:24.615: - source: 'Bild' (image_source)
11:40:24.615: - source: 'K.o' (browser_source)
11:40:24.615: - source: 'bang' (browser_source)
11:40:24.615: - source: 'Kappa' (browser_source)
11:40:24.615: - source: 'Woo' (browser_source)
11:40:24.615: - scene 'lolgame':
11:40:24.616: - source: 'Woo' (browser_source)
11:40:24.616: - filter: 'Chroma Key' (chroma_key_filter)
11:40:24.616: - source: 'loots' (browser_source)
11:40:24.616: - source: 'top don' (browser_source)
11:40:24.616: - scene 'player':
11:40:24.616: - source: 'Videoaufnahmegerät 3' (dshow_input)
11:40:24.616: - source: 'overlay' (image_source)
11:40:24.616: - source: 'Bild 3' (image_source)
11:40:24.616: - source: 'BrowserSource 3' (browser_source)
11:40:24.616: - source: 'Kappa' (browser_source)
11:40:24.616: - source: 'bang' (browser_source)
11:40:24.616: - source: 'K.o' (browser_source)
11:40:24.616: - source: 'cam' (dshow_input)
11:40:24.616: - filter: 'Zuschneiden/Pad' (crop_filter)
11:40:24.616: - scene 'pause':
11:40:24.616: - source: '2Ixfoyl.jpg' (image_source)
11:40:24.616: - source: 'Text (GDI+)' (text_gdiplus)
11:40:24.616: - source: 'BrowserSource 2' (browser_source)
11:40:24.616: - source: 'Audio Ausgabe Aufnahme 2' (wasapi_output_capture)
11:40:24.616: - source: 'BrowserSource 5' (browser_source)
11:40:24.616: - scene 'Styx':
11:40:24.616: - source: 'Bild' (image_source)
11:40:24.616: - source: 'Bild 2' (image_source)
11:40:24.616: ------------------------------------------------
11:40:26.775: ---------------------------------
11:40:26.775: [DShow Device: 'cam'] settings updated:
11:40:26.775: video device: HP Webcam HD 4310
11:40:26.775: video path: \\?\usb#vid_03f0&pid_e807&mi_00#7&1e3309d7&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
11:40:26.775: resolution: 640x480
11:40:26.775: fps: 30.00 (interval: 333333)
11:40:26.775: format: YUY2
11:40:36.296: ---------------------------------
11:40:36.296: [DShow Device: 'Videoaufnahmegerät 3'] settings updated:
11:40:36.296: video device: Elgato Game Capture HD
11:40:36.296: video path: __elgato
11:40:36.296: resolution: 1920x1080
11:40:36.296: fps: 60.00 (interval: 166666)
11:40:36.296: format: UYVY
11:40:36.296: using video device audio: yes
11:40:36.296: sample rate: 48000
11:40:36.296: channels: 2
11:40:36.296: audio type: Capture
11:41:30.814: adding 21 milliseconds of audio buffering, total audio buffering is now 64 milliseconds
11:41:31.244: adding 21 milliseconds of audio buffering, total audio buffering is now 85 milliseconds
11:41:31.675: adding 21 milliseconds of audio buffering, total audio buffering is now 106 milliseconds
11:41:32.372: adding 21 milliseconds of audio buffering, total audio buffering is now 128 milliseconds
12:14:04.540: adding 21 milliseconds of audio buffering, total audio buffering is now 149 milliseconds
12:35:49.372: adding 21 milliseconds of audio buffering, total audio buffering is now 170 milliseconds
12:35:50.992: adding 21 milliseconds of audio buffering, total audio buffering is now 192 milliseconds
12:35:52.346: adding 21 milliseconds of audio buffering, total audio buffering is now 213 milliseconds
12:48:09.089: adding 21 milliseconds of audio buffering, total audio buffering is now 234 milliseconds
12:56:11.676: Settings changed (outputs)
12:56:11.676: ------------------------------------------------
12:56:13.835: ---------------------------------
12:56:13.846: [NVENC encoder: 'recording_h264'] settings:
12:56:13.846: rate_control: CBR
12:56:13.846: bitrate: 15000
12:56:13.846: cqp: 0
12:56:13.846: keyint: 120
12:56:13.846: preset: hp
12:56:13.846: profile: high
12:56:13.846: level: auto
12:56:13.846: width: 1280
12:56:13.846: height: 720
12:56:13.846: 2-pass: false
12:56:13.846: b-frames: 2
12:56:13.846: GPU: 2
12:56:13.846:
12:56:13.870: fatal: No NVENC capable devices found
12:56:13.883: [NVENC encoder: 'recording_h264'] Failed to open NVENC codec: Generic error in an external library
13:07:22.076: Settings changed (outputs)
13:07:22.076: ------------------------------------------------
13:07:25.194: ---------------------------------
13:07:25.194: [NVENC encoder: 'recording_h264'] settings:
13:07:25.194: rate_control: CBR
13:07:25.194: bitrate: 10000
13:07:25.194: cqp: 0
13:07:25.194: keyint: 120
13:07:25.194: preset: hq
13:07:25.194: profile: high
13:07:25.194: level: auto
13:07:25.194: width: 1280
13:07:25.194: height: 720
13:07:25.194: 2-pass: true
13:07:25.194: b-frames: 2
13:07:25.194: GPU: 6
13:07:25.194:
13:07:25.195: fatal: No NVENC capable devices found
13:07:25.195: [NVENC encoder: 'recording_h264'] Failed to open NVENC codec: Generic error in an external library
All drivers are up to date
i hope anyone can help me :/
Don't change settings when you don't know what they do, you changed the GPU setting from it's default of 0.
