Question / Help Hikvision DS-2DE4425/W-DE RTSP problems.
DanGol
Dear,
We want to use the Hikvision DS-2DE4425/W-DE to live capture the building of our bonfire to youtube.
I use this link: rtsp://admin:[email protected].:554/Streaming/Channels/101 to get the RTSP stream. The stream does work on VLC media player on my computer and on the RTSP player on my phone, but when i try to use the "Mediasource" option in OBS it doesn't work, i'm only getting a black screen.
It did work before with other camera's though. Anyone know how to fix this?
This is the logfile:
00:29:48.621: [Media Source 'Mediabron']: settings:
00:29:48.621: input:
00:29:48.621: input_format: (null)
00:29:48.621: speed: 100
00:29:48.621: is_looping: no
00:29:48.621: is_hw_decoding: yes
00:29:48.621: is_clear_on_media_end: yes
00:29:48.621: restart_on_activate: yes
00:29:48.621: close_when_inactive: no
00:29:48.630: User added source 'Mediabron' (ffmpeg_source) to scene 'Scène 3'
00:29:56.901: [Media Source 'Mediabron']: settings:
00:29:56.901: input: rtsp://admin:[email protected]:554/Streaming/Channels/101
00:29:56.901: input_format:
00:29:56.901: speed: 100
00:29:56.901: is_looping: no
00:29:56.901: is_hw_decoding: no
00:29:56.901: is_clear_on_media_end: no
00:29:56.901: restart_on_activate: no
00:29:56.901: close_when_inactive: yes
00:29:56.931: warning: 'circular_buffer_size' option was set but it is not supported on this build (pthread support is required)
00:29:56.932: warning: 'circular_buffer_size' option was set but it is not supported on this build (pthread support is required)
