Question / Help Hikvision DS-2DE4425IW-DE RTSP problems
DanGol
Dear,
We would like to livestream the building of worlds biggest bonfire next week 24/7 to youtube. For this we would like to use the Hikvision DS-2DE4425IW-DE with OBS Studio. Unfortunately, i can open this stream url rtsp://admin:[email protected]:554/Streaming/Channels/101 everywhere, except in OBS, where i keep getting a black screen.
Logfile says this:
00:29:48.630: User added source 'Mediabron' (ffmpeg_source) to scene 'Scène 3'
00:29:56.901: [Media Source 'Mediabron']: settings:
00:29:56.901: input: rtsp://admin:[email protected]:554/Streaming/Channels/101
00:29:56.901: input_format:
00:29:56.901: speed: 100
00:29:56.901: is_looping: no
00:29:56.901: is_hw_decoding: no
00:29:56.901: is_clear_on_media_end: no
00:29:56.901: restart_on_activate: no
00:29:56.901: close_when_inactive: yes
00:29:56.931: warning: 'circular_buffer_size' option was set but it is not supported on this build (pthread support is required)
00:29:56.932: warning: 'circular_buffer_size' option was set but it is not supported on this build (pthread support is required)
00:30:07.072: warning: UDP timeout, retrying with TCP
00:30:07.082: error: method PAUSE failed: 551 Option not supported
00:30:07.083: warning: Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
00:30:07.083: Consider increasing the value for the 'analyzeduration' and 'probesize' options
00:30:17.169: warning: UDP timeout, retrying with TCP
00:30:17.177: error: method PAUSE failed: 551 Option not supported
00:30:17.177: MP: av_read_frame failed: Operation not permitted (-1)
Anybody here who can help me? Please
Kind regards,
Danny
I am having a blank screen as well.
I have Hikvision DS-2CV1021G0-IDW1
Did you find the cure for it ?
thanks
Hi! Test using the Hikvison VSPlayer software where you can use the url rtsp: // user: pwd@ip: port / Stream / Channels / 101.
If you can open the image from the camera, you may be able to open it in the VLC midea source. Let us know if you succeeded.
