When I'm not streaming, everything is normal. But when I do stream any video game, my ping is high for no reason making my experience overall infuriating. Is there a fix to this?
Not 'no reason' - most likely an easily visible reason
real-time video encoding is VERY computationally demanding.
I recommend monitoring hardware resource (CPU, GPU, RAM, Disk I/O, etc) utilization [for ex. using Task manager’s Performance tab and/or Resource Monitor] to see if your system is being maxed out with your settings https://obsproject.com/wiki/General-Performance-and-Encoding-Issues
In my experience, which may or may not apply to your situation, your observation is associated with an under-powered computer for what you are asking it to do. You ignored the pinned posts in this forum on posting OBS log when asking for help, so I and others can only guess as to your issue(s).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
