Question / Help HP Pavilion 15-cc594nd (2GR86EA) OBS Recording settings
hplaptop
Hi, Guys, I have an HP Laptop 15-cc594nd (2GR86EA), and when I record when I'm playing mobile games it does not lag or freeze at all. I usually mirror it with airserver from my phone to my laptop. Then every time I try to play a game on my laptop and record it, it lags like crazy!!! Games like fortnite will lag in both the game and the video in the recording. Other games will play smoothly but the video will be really laggy and freeze most of the time, Games like Realm Royal.
So can anyone please help me with the OBS settings that will fit this laptop. That will run and play smoothly both in the game and the video..!!
Here are the specs
product number
2GR86EA
Product name
HP Pavilion - 15-cc594nd
Microprocessor
Intel® Core™ i7-7500U (2.7 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
Memory, standard
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
  • NVIDIA® GeForce® 940MX (4 GB DDR3 dedicated)
  • Discrete
Hard drive
1 TB 5400 rpm SATA
Display
39.6 cm (15.6") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
HP Imagepad with multi-touch gesture support
Wireless connectivity
Intel® 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
Network interface
Integrated 10/100/1000 GbE LAN
Expansion slots
1 multi-format SD media card reader
External Ports
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
Minimum dimensions (W x D x H)
37.8 x 25.21 x 1.99 cm
Weight
1.91 kg
Power supply type
65 W AC power adapter
Battery type
3-cell, 41 Wh Li-ion
Operating system
Windows 10 Home 64
