INSTANT OBS CRASHING- Please Help Details Inside
yoggerzz
Unhandled exception: e06d7363
Date/Time: 2022-02-15, 16:46:48
Fault address: 7FFE60B34F69 (c:\windows\system32\kernelbase.dll)
libobs version: 27.2.0 (64-bit)
Windows version: 10.0 build 19044 (release: 2009; revision: 1526; 64-bit)
CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
here is part of the crash log. did update today and bam. can't run OBS. instant crashes. reinstalled, restarted computer. any help much appreciated.
update your GPU drivers !
check you windows instalation open a CMD window as admin type in
1st "DISM.exe /Online /Cleanup-image /Restorehealth"
wait to finish then
2nd "sfc /scannow"
wait to finish then
2nd "sfc /scannow"
it says the online/cleanup-image/restorehealth option is unknown. after running the second command it said that corrupted files were repaired but still have the exact same issue and it wont launch OBS
thank you. got error: 87 when i ran the first command.
i am completely up to date on all OS things and drivers. this is making me go crazy. LITERALLY used OBS right before the update to record a video. literally. updated and boom. everything is messed up. however now streamlabs OBS is working. i really dont want to use them.
did you have start the cmd with admin privilegs ?
is in the window name running as Admin?
try this commands
  • DISM /Online /Cleanup-image /Scanhealth
  • DISM /Online /Cleanup-image /Restorehealth
try also the aio runtime installer
absolutely nothing is working.. i just did a clean reinstall of GPU drivers, the program, i did all those commands and it ran the scans and said no corruption or anything. and still obs just will not launch.
