Question / Help Logitech C920 & C922 Not Working Well Together
Harmonia
I've been using my C922 for over a year now, and recently got a C920 as another camera. When I add the C920, it appears as more of a square, about 1440 x 1080, instead of 1920 x 1080. Adjusting the camera settings in Logitech Camera Settings does nothing. Installing USB drivers into both camera does nothing.
Chromacam, software I don't even want, is run on my computer. Selecting either one of the camera with Chromacam makes it a 1080p rectangle, but the other is left 1440 x 1080. If I uninstall the software, both cameras are 1440 x 1080. With the software, only one of the cameras can be 1080p, whichever I select, but never both.
Anyone have any input on this? Thanks in advance
I've noticed that c922 & c920 don't play well with each other on OBS. Not sure why. I'm currently running a 12 cam setup & when I have my 920's connected at the same time as my 922 the 920's wig out & the 922 won't work. As soon as I disconnect the 922 all the 920's work fine.
Do you have this problem on your laptop or on PC? I have Logitech C922 and C930e. On big comp work perfect. But on laptop, where the max. screen resolution 1600 x 900, only first connected camera work on 1920 x 1080, the second only on 1600 x 900. If I also set the resolution to 1920 x 1080 on another camera, it turns off. When I get back to default resolution, both cameras are functioning normally again.
