Looking for help with obs video disconnecting from youtube live stream
Stream78
In two different occasions connection to YouTube is lost and essentially video is dropped, is there anything I can do to prevent this. Using Android Mobile phone via droidcam as video capture device Attached log files
22:56:47.257: ==== Streaming Start ===============================================
23:05:43.531: [DroidCamOBS] decoder catchup: decodeQueue: 0 recieveQueue: 27
23:30:25.203: [rtmp stream: 'simple_stream'] bitrate decreased to: 8200
23:30:26.162: [rtmp stream: 'simple_stream'] bitrate decreased to: 3700
23:30:27.394: [rtmp stream: 'simple_stream'] bitrate decreased to: 1200
23:30:27.404: [qsv encoder: 'simple_video_stream'] Failed to reconfigure
23:30:31.404: [rtmp stream: 'simple_stream'] bitrate increased to: 2100, waiting
23:30:31.420: [qsv encoder: 'simple_video_stream'] Failed to reconfigure
23:34:10.857: ==== Shutting down ==================================================
23:34:10.935: [DroidCamOBS] stopping
2nd failure
22:58:02.631: ==== Streaming Start ===============================================
23:42:35.858: [rtmp stream: 'simple_stream'] bitrate decreased to: 8700
23:42:37.275: [rtmp stream: 'simple_stream'] bitrate decreased to: 200
23:42:37.290: [qsv encoder: 'simple_video_stream'] Failed to reconfigure
23:42:41.291: [rtmp stream: 'simple_stream'] bitrate increased to: 1100, waiting
23:42:41.307: [qsv encoder: 'simple_video_stream'] Failed to reconfigure
23:45:46.168: [DroidCamOBS] @decoder alloc: size=18968
23:45:46.168: [DroidCamOBS] @decoder alloc: size=36379
23:45:46.179: [DroidCamOBS] @decoder alloc: size=27839
23:45:46.312: [DroidCamOBS] @decoder alloc: size=22821
23:45:46.473: [DroidCamOBS] @decoder alloc: size=21237
23:45:46.615: [DroidCamOBS] @decoder alloc: size=34384
23:45:46.682: [DroidCamOBS] @decoder alloc: size=20759
23:45:47.177: [DroidCamOBS] @decoder alloc: size=29512
23:48:51.061: [DroidCamOBS] read header recv returned 0
23:48:53.062: [DroidCamOBS] ~decoder alloc_count=0
23:48:53.207: [DroidCamOBS] read header recv returned 0
23:48:55.207: [DroidCamOBS] ~decoder alloc_count=0
23:48:55.679: [DroidCamOBS] have config: 30
23:48:55.683: [DroidCamOBS] @decoder alloc: size=103319
23:48:59.295: [DroidCamOBS] @decoder alloc: size=23617
23:48:59.314: [DroidCamOBS] @decoder alloc: size=37136
23:50:09.799: [DroidCamOBS] read header recv returned 0
23:50:11.802: [DroidCamOBS] ~decoder alloc_count=0
23:50:11.910: [DroidCamOBS] "adb fwd" exit value 1
23:50:11.910: [DroidCamOBS] adb_forward failed
23:50:14.035: [DroidCamOBS] "adb fwd" exit value 1
2nd failure
The crash is happening on a custom dock or browser source.
Please read and follow directions and recommendations on the analyzer:
Try reducing to 30fps or change the output resolution to 720p at 60 fps.
Filters use more CPU, so consider not using it.
The easy way to fix a configuration is running the Auto-configuration Wizard (tools menu) and apply the settings it gives. Do not change a thing. Restart OBS and test.
