Looks so dark
Full color range should not be used, and windows' built in media player also should not be used.
An extremely large percentage of video software is hardcoded to expect partial range and will cause color distortion when using full range.
Windows' built in media player doesn't recognize color ranges properly and will also cause color distortion.
why do you change settings you don't understand? Clean your profile and use the standard values and use auto config wizard.
Thank you both that worked
