Hi there, I hope you are having a wonderfull day, recently I'm having some issues when I'm trying to recording my screen when I'm playing League of Legends or Heroes of the Storm... or any game, everything was fine till 2 days ago, I was able to play and recording without any drop frames or lag during the game, just to be clear, recording, not streaming, but as I said 2 days ago just suddently when I was playing and hit the record option I just see a message... encoding overloaded and my CPU get some crazy numbers like -853652358236.66, I have a Macbook pro 16 inch 2019 model with 2.4ghz intel core i9 (8 cores) 64gb RAM and AMD Radeon Pro 5600M 8 GB, Intel UHD Graphics 630 1536 MB
Any help to record my games without issues I will be appressiate, thank you in advance
22:36:11.086: CPU Name: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
22:36:11.086: CPU Speed: 2400MHz
22:36:11.087: Physical Cores: 8, Logical Cores: 16
22:36:11.087: Physical Memory: 65536MB Total
22:36:11.087: OS Name: Mac OS X (NSMACHOperatingSystem)
22:36:11.087: OS Version: Version 10.15.6 (Build 19G2021)
22:36:11.087: Kernel Version: 19.6.0
22:36:11.099: hotkeys-cocoa: Using layout 'com.apple.keylayout.US'
22:36:11.100: Portable mode: false
22:36:11.192: OBS 26.1.0 (mac)
22:36:11.192: ---------------------------------
22:36:11.192: audio settings reset:
22:36:11.192: samples per sec: 48000
22:36:11.192: speakers: 2
22:36:11.193: ---------------------------------
22:36:11.193: Initializing OpenGL...
22:36:12.629: Loading up OpenGL on adapter ATI Technologies Inc. AMD Radeon Pro 5600M OpenGL Engine
22:36:12.629: OpenGL loaded successfully, version 4.1 ATI-3.10.16, shading language 4.10
22:36:12.699: ---------------------------------
22:36:12.699: video settings reset:
22:36:12.699: base resolution: 4096x2560
22:36:12.699: output resolution: 4096x2560
22:36:12.699: downscale filter: Lanczos
22:36:12.699: fps: 60/1
22:36:12.699: format: NV12
22:36:12.699: YUV mode: 709/Partial
22:36:12.699: NV12 texture support not available
22:36:12.699: Audio monitoring device:
22:36:12.699: name: Por defecto
22:36:12.699: id: default
22:36:12.700: Failed to load 'en-US' text for module: 'decklink-captions.so'
22:36:12.701: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
22:36:12.765: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
22:36:12.765: No blackmagic support
22:36:12.766: [mac-virtualcam] version=1.3.0
22:36:12.802: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
22:36:12.816: [obs-browser]: Version 2.9.1
22:36:12.816: [obs-browser]: CEF Version 75.1.16+g16a67c4+chromium-75.0.3770.100
22:36:12.823: os_dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib->/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib): dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib, 257): image not found
22:36:12.823:
22:36:12.823: Couldn't find VLC installation, VLC video source disabled
22:36:12.823: ---------------------------------
22:36:12.823: Loaded Modules:
22:36:12.823: vlc-video.so
22:36:12.823: text-freetype2.so
22:36:12.823: rtmp-services.so
22:36:12.823: obs-x264.so
22:36:12.823: obs-vst.so
22:36:12.823: obs-transitions.so
22:36:12.823: obs-outputs.so
22:36:12.823: obs-libfdk.so
22:36:12.823: obs-filters.so
22:36:12.823: obs-ffmpeg.so
22:36:12.823: obs-browser.so
22:36:12.823: mac-vth264.so
22:36:12.823: mac-virtualcam.so
22:36:12.823: mac-syphon.so
22:36:12.823: mac-decklink.so
22:36:12.823: mac-capture.so
22:36:12.823: mac-avcapture.so
22:36:12.823: linux-jack.so
22:36:12.823: image-source.so
22:36:12.824: frontend-tools.so
22:36:12.824: decklink-ouput-ui.so
22:36:12.824: decklink-captions.so
22:36:12.824: coreaudio-encoder.so
22:36:12.824: ---------------------------------
22:36:12.824: os_dlopen(../obs-plugins/obs-browser->../obs-plugins/obs-browser.so): dlopen(../obs-plugins/obs-browser.so, 257): image not found
22:36:12.824:
22:36:12.824: ==== Startup complete ===============================================
22:36:12.845: Switched to Preview/Program mode
22:36:12.845: ------------------------------------------------
22:36:12.846: All scene data cleared
22:36:12.846: ------------------------------------------------
22:36:12.875: coreaudio: device 'Micrófono: MacBook Pro' initialized
22:36:12.875: [Loaded global audio device]: 'Mic/Aux'
22:36:12.899: Switched to scene 'Escena'
22:36:12.899: ------------------------------------------------
22:36:12.899: Loaded scenes:
22:36:12.899: - scene 'Escena':
22:36:12.899: - source: 'Captura de pantalla' (display_capture)
22:36:12.938: [rtmp-services plugin] Remote update of URL "https://obsproject.com/obs2_update/rtmp-services/package.json" failed: error setting certificate verify locations: CAfile: /usr/local/etc/[email protected]/cert.pem CApath: /usr/local/etc/[email protected]/certs
22:36:12.997: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Mic/Aux)
22:36:12.997:
22:36:12.823:
22:36:12.824:
22:36:12.997:
