Question / Help Microphone problems
Yuudai
Having trouble getting my mic working *worked before* with Studio, I have set it to listen to make sure the mic is working, and I can hear myself..I turn it off, set the mic line to what my heatset mic is..And nothing,the bar doesn't even move at all
OBS is looking for an audio device it cannot find.
20:02:03.396: WASAPI: Device 'Speakers (Logitech G35 Gaming Headset)' initialized
20:02:03.412: [WASAPISource::TryInitialize]:[Microphone (Logitech G35 Gaming Headset)] Failed to get initialize audio client: 80070005
20:02:03.412: [WASAPISource::WASAPISource] Device '{0.0.1.00000000}.{3c93f44b-4734-4b8f-9807-e2f57b3fea83}' not found. Waiting for device
I'm not sure what would be causing that..The headphones work fine, so in my mind, its something with the mic?
Yes, that's what it is saying. Perhaps another program has exclusive access to the device, or perhaps Windows permission settings are preventing OBS from accessing it?
Hmm I think I know how to check the exclusive access,but how would I check to see if windows isn't allowing it in OBS?
Windows update. This setting is new, and the default for all apps after it was created is to deny access unless explicitly allowed by the user.
