Question / Help New OBS User Help/Dropped Frames
TheLimboman7
Hello, I am new to OBS and Twitch streaming and have recently been trying to stream some of my game play of different games such as CSGO and Fortnite. The stream starts off fine as I monitor the stream on my phone and everything seems to be running smoothly in the in game lobby. The game starts and the stream has 2 sec freezes every 5 or so seconds. I don't understand what the problem is and I've tried changing the bit rate anywhere from 1500-3000kbps. The lower the bit rate the smoother the stream but it still stutters like crazy when you get into some action like a firefight, or you land anywhere that's populated. My in game FPS doesn't seem to be affected at all with my FPS dropping to a respectable 180fps in Fortnite, I do play on everything low except anti aliasing and view distance however (which are both high).
PC specs:
-MSI Gtx 1060 6gb OC edition
-i5 7500 @ 3.2ghz
-8gb of RAM @ 2133mhz
Last speedtest.net info:
-ISP Telstra
-9ms ping
-27.38mbps down
-17.34mbps up
OBS encoding settings:
-x264
-Enforce streaming encoding settings ON
-Rescale output 1280x720
-CBR
-bitrate 2000 - i changed to 1785 as recommended by twitch when I ran a test stream, still dropping huge frames on stream but not pc
-No custom buffer
-keyframe interval 2
-cpu faster
-profile main
Video settings:
-Base res 1920x1080
-output 1280x720
-Bicubic
-30fps
Fortnite test stream log:
[16:17:33.143: CPU Name: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
16:17:33.143: CPU Speed: 3408MHz
16:17:33.144: Physical Cores: 4, Logical Cores: 4
16:17:33.144: Physical Memory: 8160MB Total, 2222MB Free
16:17:33.144: Windows Version: 10.0 Build 17134 (revision: 112; 64-bit)
16:17:33.144: Running as administrator: true
16:17:33.144: Aero is Enabled (Aero is always on for windows 8 and above)
16:17:33.144: Windows 10 Gaming Features:
16:17:33.144: Game Bar: On
16:17:33.144: Game DVR: On
16:17:33.144: Game DVR Background Recording: Off
16:17:33.145: Sec. Software Status:
16:17:33.147: Windows Defender Antivirus: enabled (AV)
16:17:33.147: Windows Firewall: enabled (FW)
16:17:33.148: Windows Defender Antivirus: enabled (ASW)
16:17:33.148: Portable mode: false
16:17:33.309: OBS 21.1.0 (64bit, windows)
16:17:33.309: ---------------------------------
16:17:33.310: ---------------------------------
16:17:33.310: audio settings reset:
16:17:33.310: samples per sec: 44100
16:17:33.310: speakers: 2
16:17:33.312: ---------------------------------
16:17:33.312: Initializing D3D11...
16:17:33.312: Available Video Adapters:
16:17:33.313: Adapter 1: NVIDIA GeForce GTX 1060 6GB
16:17:33.314: Dedicated VRAM: 2051014656
16:17:33.314: Shared VRAM: 4278319104
16:17:33.314: output 1: pos={0, 0}, size={1920, 1080}, attached=true
16:17:33.316: Loading up D3D11 on adapter NVIDIA GeForce GTX 1060 6GB (0)
16:17:33.389: D3D11 loaded successfully, feature level used: 45056
16:17:34.517: ---------------------------------
16:17:34.517: video settings reset:
16:17:34.517: base resolution: 1920x1080
16:17:34.517: output resolution: 1280x720
16:17:34.517: downscale filter: Bicubic
16:17:34.517: fps: 30/1
16:17:34.517: format: NV12
16:17:34.517: YUV mode: 601/Partial
16:17:34.520: Audio monitoring device:
16:17:34.520: name: Default
16:17:34.520: id: default
16:17:34.521: ---------------------------------
16:17:34.525: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
16:17:34.530: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
16:17:34.626: [AMF] AMF Test failed due to one or more errors.
16:17:34.626: Failed to initialize module 'enc-amf.dll'
16:17:34.652: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
16:17:34.654: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
16:17:34.654: (127)
16:17:34.654: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
16:17:34.656: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
16:17:34.660: [browser_source: 'Version: 1.31.0']
16:17:34.680: NVENC supported
16:17:34.777: Couldn't find VLC installation, VLC video source disabled
16:17:34.791: No blackmagic support
16:17:34.804: ---------------------------------
16:17:34.804: Loaded Modules:
16:17:34.804: win-wasapi.dll
16:17:34.805: win-mf.dll
16:17:34.805: win-dshow.dll
16:17:34.805: win-decklink.dll
16:17:34.805: win-capture.dll
16:17:34.805: vlc-video.dll
16:17:34.805: text-freetype2.dll
16:17:34.805: rtmp-services.dll
16:17:34.805: obs-x264.dll
16:17:34.805: obs-vst.dll
16:17:34.805: obs-transitions.dll
16:17:34.805: obs-text.dll
16:17:34.805: obs-qsv11.dll
16:17:34.805: obs-outputs.dll
16:17:34.805: obs-filters.dll
16:17:34.805: obs-ffmpeg.dll
16:17:34.805: obs-browser.dll
16:17:34.805: image-source.dll
16:17:34.805: frontend-tools.dll
16:17:34.805: enc-amf.dll
16:17:34.805: coreaudio-encoder.dll
16:17:34.805: ---------------------------------
16:17:34.805: ==== Startup complete ===============================================
16:17:34.815: All scene data cleared
16:17:34.815: ------------------------------------------------
16:17:34.887: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
16:17:35.033: WASAPI: Device 'Microphone (Realtek High Definition Audio)' initialized
16:17:35.069: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
16:17:36.030: [game-capture: 'Game Capture 2'] attempting to hook fullscreen process: explorer.exe
16:17:36.030: [game-capture: 'Game Capture 2'] cannot capture explorer.exe due to being blacklisted
16:17:36.033: Switched to scene 'Scene 2'
16:17:36.034: ------------------------------------------------
16:17:36.034: Loaded scenes:
16:17:36.034: - scene 'Scene 2':
16:17:36.034: - source: 'Game Capture 2' (game_capture)
16:17:36.034: - source: 'Display Capture 2' (monitor_capture)
16:17:36.666: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
16:18:20.065: User added source 'Fortnite' (game_capture) to scene 'Scene 2'
16:19:27.810: User Removed source 'Fortnite' (game_capture) from scene 'Scene 2'
16:19:30.818: User Removed source 'Display Capture 2' (monitor_capture) from scene 'Scene 2'
16:19:33.710: User Removed source 'Game Capture 2' (game_capture) from scene 'Scene 2'
16:19:46.152: Source 'Scene 2' renamed to 'Scene 1'
16:19:52.644: User added source 'Game Capture' (game_capture) to scene 'Scene 1'
16:22:10.854: [game-capture: 'Game Capture'] attempting to hook fullscreen process: FortniteClient-Win64-Shipping.exe
16:22:10.858: [game-capture: 'Game Capture'] using helper (compatibility hook)
16:22:10.887: [game-capture: 'Game Capture'] hook not loaded yet, retrying..
16:22:13.888: [game-capture: 'Game Capture'] attempting to hook fullscreen process: FortniteClient-Win64-Shipping.exe
16:22:13.915: [game-capture: 'Game Capture'] d3d11 shared texture capture successful
16:22:13.921: [game-capture: 'Game Capture'] shared texture capture successful
16:22:33.416: ---------------------------------
16:22:33.417: [x264 encoder: 'streaming_h264'] preset: faster
16:22:33.417: [x264 encoder: 'streaming_h264'] profile: main
16:22:33.418: [x264 encoder: 'streaming_h264'] settings:
16:22:33.418: rate_control: CBR
16:22:33.418: bitrate: 2000
16:22:33.418: buffer size: 2000
16:22:33.418: crf: 0
16:22:33.418: fps_num: 30
16:22:33.418: fps_den: 1
16:22:33.418: width: 1280
16:22:33.418: height: 720
16:22:33.418: keyint: 60
16:22:33.418:
16:22:33.418: [x264 encoder: 'streaming_h264'] custom settings: scenecut=0
16:22:33.426: ---------------------------------
16:22:33.430: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
16:22:33.430:
16:22:33.438: Output 'adv_stream': 20 second delay active, preserve on disconnect is on
16:22:53.424: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-syd.twitch.tv/app...
16:22:53.448: [rtmp stream: 'adv_stream'] Interface: Edimax Wi-Fi N150 Bluetooth4.0 USB Adapter (802.11, 63 mbps)
16:22:54.435: [rtmp stream: 'adv_stream'] Connection to rtmp://live-syd.twitch.tv/app successful
16:22:54.435: ==== Streaming Start ===============================================
16:23:42.469: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
16:28:29.782: [rtmp stream: 'adv_stream'] User stopped the stream
16:28:29.782: Output 'adv_stream': stopping
16:28:29.782: Output 'adv_stream': Total frames output: 9735
16:28:29.782: Output 'adv_stream': Total drawn frames: 10090
16:28:29.782: Video stopped, number of skipped frames due to encoding lag: 5981/10690 (55.9%)
16:28:29.784: ==== Streaming Stop ================================================
16:28:47.336: Settings changed (outputs)
16:28:47.336: ------------------------------------------------
16:29:16.037: Settings changed (stream 1)
16:29:16.037: ------------------------------------------------
16:29:49.918: ---------------------------------
16:29:49.918: [x264 encoder: 'streaming_h264'] preset: faster
16:29:49.918: [x264 encoder: 'streaming_h264'] profile: main
16:29:49.918: [x264 encoder: 'streaming_h264'] settings:
16:29:49.918: rate_control: CBR
16:29:49.918: bitrate: 1785
16:29:49.918: buffer size: 1785
16:29:49.918: crf: 0
16:29:49.918: fps_num: 30
16:29:49.918: fps_den: 1
16:29:49.918: width: 1280
16:29:49.918: height: 720
16:29:49.918: keyint: 60
16:29:49.918:
16:29:49.918: [x264 encoder: 'streaming_h264'] custom settings: scenecut=0
16:29:49.921: ---------------------------------
16:29:49.921: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
16:29:49.921:
16:29:49.922: Output 'adv_stream': 20 second delay active, preserve on disconnect is on
16:30:09.922: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-syd.twitch.tv/app...
16:30:09.940: [rtmp stream: 'adv_stream'] Interface: Edimax Wi-Fi N150 Bluetooth4.0 USB Adapter (802.11, 56 mbps)
16:30:11.237: [rtmp stream: 'adv_stream'] Connection to rtmp://live-syd.twitch.tv/app successful
16:30:11.237: ==== Streaming Start ===============================================
16:50:47.537: [rtmp stream: 'adv_stream'] User stopped the stream
16:50:47.537: Output 'adv_stream': stopping
16:50:47.537: Output 'adv_stream': Total frames output: 36995
16:50:47.537: Output 'adv_stream': Total drawn frames: 37126 (37128 attempted)
16:50:47.537: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 2 (0.0%)
16:50:47.538: Video stopped, number of skipped frames due to encoding lag: 5589/37729 (14.8%)
16:50:47.539: ==== Streaming Stop ================================================
16:51:40.954: [game-capture: 'Game Capture'] capture window no longer exists, terminating capture
16:51:40.955: [game-capture: 'Game Capture'] capture stopped]
