Bug Report Obs 0.11.1 crashes while streaming + recording (FFMpeg)
dayzru
It was doing well in the previous version. Same settings. I was able to stream and record locally (FFMpeg).
The thing is that I can do record with no streaming or I can stream without recording.
If I try to start the recording while streaming, OBS crashes.
I can do streaming and do the standard flv recording, but that takes more CPU and is not good for editing.
I'm not worrying much about this issue, just wanted to give you some info, hope that helps.
  • 2015-07-14 21-59-24 fail.txt
  • obscrash.txt
    obscrash.txt
We'll look into this, but in the meantime, have you checked out the other new recording options that let you recording natively in MP4/MPV in OBS MP without needing FFmpeg?
Thank you, the native MP4 record functions well while streaming.
I'll just have to use other editing software for that.
