Question / Help OBS & 2 x Elgato HD60S problems
JayX
Hi y'all,
I've following setup:
My Sony A7III is connected to the Elgato HD60S
and onther PC is connected to my second Elgato HD60S
In OBS i can see each stream separately but not both at the same time. But sometimes i can see both but not for along time.
I just have one USB 3 Port on my laptop, is that the problem?
LOG File
Thanks for your help
Sounds like a bandwidth problem at first. I'd try set both to a low resolution and see what happens.
USB3 delivers about 5gbps - *total*. 720p uses about 3gbps uncompressed video feed. So if you run both cards from same usb 3 port, yes.
edit: consider small res for cam, and a bit higher for game, and u can make it work.
Thank you for your help. But in the meantime I switched to a PC. SO the Problem is solved.
