OBS crashes on every exit.
I also frequently have it crash on exit on multiple computers. My best guess is that it's one or a few of the plugins I have installed.
This crash is in the auburn sounds graillon 2 VST plugin.
If others with a crash on close don't have this plugin installed, they don't have the same issue.
THIS SOLVED IT!
Thank you so much! I don't believe I use decklink, so I can't comment on that front.
