Question / Help Obs game capture is crashing fortnite
Twitch_Cortana5
In order to fix this i can just use display capture but why would i want to play a game that is choppy and die in fortnite infront of my viewers like a noob so i like game capture it provides smooth game play the problem is is that when i capture fortnite using game capture specific window fortnite cant get through one solo match without taking a big ol dump on its self.... So heres the thing theres two logs i will provide for this in order for you guys to interpret a fix.
Log Name: Application
Source: Application Error
Date: 7/21/2018 2:42:33 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: Cortana5
Description:
Faulting application name: Streamlabs OBS.exe, version: 0.9.5.0, time stamp: 0x5b3bcb5d
Faulting module name: ucrtbase.dll, version: 10.0.17134.165, time stamp: 0xfdc3d6f1
Exception code: 0xc0000409
Fault offset: 0x000000000006e86e
Faulting process id: 0x152c
Faulting application start time: 0x01d420bbbb1d98db
Faulting application path: C:\Program Files\Streamlabs OBS\Streamlabs OBS.exe
Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
Report Id: dc8717ca-693d-48da-8b38-06eab0a518c9
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2018-07-21T06:42:33.266855100Z" />
<EventRecordID>13062</EventRecordID>
<Channel>Application</Channel>
<Computer>Cortana5</Computer>
<Security />
</System>
<EventData>
<Data>Streamlabs OBS.exe</Data>
<Data>0.9.5.0</Data>
<Data>5b3bcb5d</Data>
<Data>ucrtbase.dll</Data>
<Data>10.0.17134.165</Data>
<Data>fdc3d6f1</Data>
<Data>c0000409</Data>
<Data>000000000006e86e</Data>
<Data>152c</Data>
<Data>01d420bbbb1d98db</Data>
<Data>C:\Program Files\Streamlabs OBS\Streamlabs OBS.exe</Data>
<Data>C:\WINDOWS\System32\ucrtbase.dll</Data>
<Data>dc8717ca-693d-48da-8b38-06eab0a518c9</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Crashing in the game indicates conflicts with overlay software.
And no just "change the streamlabs to obs and you got your thread" is not the case. They have changed enough about how the program operates that they are NOT the same.
They may not be the same but its the same error code with the dll file crashing obs stream thats why i downloaded the streams labs obs and it does the same thing....So that being said it couldnt be my overlays could it ? if so what do you impose to do differently
Conflicts with Game Capture: Other capture programs, Razer Synapse (disable heatmaps), graphics mods like ENBSeries and SweetFX, and any type of software or utility that displays an in-game overlay like EVGA Precision, MSI Afterburner, RivaTuner, TS3/Mumble overlays, Dolby Axon, Raptr, Overwolf, etc. If you use D3DGear it must be uninstalled completely.
hello idk if any of you will see this but im having this problem my fortnite crashes only on game capture and my game capture doesnt crash any of my other games, if you fixed it cortana can you help me please
In discord disable in game overlay, you also need to do this in NVIDIA Experience after go and disable the game bar on windows, worked for me.
after that you can turn on your instant replays and others and it should work
Please reply to me when you find out a solution. Having the exact problem, both from obs and streamlabs.
