Question / Help OBS Studio does not minimize to tray
Axel0689
Hi, everybody. As the title says, although I have activated the checkpoints, OBS does not minimize itself to an icon.
I also set the compatibility with Windows 7. And nothing, the icon remains on the taskbar (and also in the tray).
If there's a way to solve this problem/bug, I'd really appreciate it. I await all possible advice, suggestions. Thank you.
Try to uncheck ENABLE...That's how mine is..
If I take the tick off, this happens:
And what have I solved? I need it to not appear in the bar applications and it needs to appear in the tray (especially while I'm making the recordings).
Thanks anyway
As far as I know any program that's running shows there...
Maybe someone else knows how to prevent it from showing in the task bar.
