Question / Help OBS won't run at intelHD
sinyo1015
the program listed running, but for a moment it disappeared
here's my log
05:40:10.990: CPU Name: Intel(R) Core(TM) i3-2328M CPU @ 2.20GHz
05:40:10.990: CPU Speed: 2195MHz
05:40:10.990: Physical Cores: 2, Logical Cores: 4
05:40:10.990: Physical Memory: 3931MB Total, 1934MB Free
05:40:10.990: Windows Version: 10.0 Build 16299 (revision: 371; 64-bit)
05:40:10.990: Running as administrator: false
05:40:10.990: Aero is Enabled (Aero is always on for windows 8 and above)
05:40:10.990: Windows 10 Gaming Features:
05:40:10.990: Game Bar: Off
05:40:10.990: Game DVR: Off
05:40:10.990: Game DVR Background Recording: On
05:40:11.000: Sec. Software Status:
05:40:11.003: Windows Defender Antivirus: enabled (AV)
05:40:11.003: Windows Firewall: enabled (FW)
05:40:11.004: Windows Defender Antivirus: enabled (ASW)
05:40:11.131: Portable mode: false
05:40:15.055: OBS 21.1.2 (64bit, windows)
05:40:15.055: ---------------------------------
05:40:15.057: ---------------------------------
05:40:15.057: audio settings reset:
05:40:15.057: samples per sec: 44100
05:40:15.057: speakers: 2
05:40:15.170: ---------------------------------
05:40:15.170: Initializing D3D11...
05:40:15.170: Available Video Adapters:
05:40:15.173: Adapter 1: Intel(R) HD Graphics 3000
05:40:15.173: Dedicated VRAM: 134217728
05:40:15.173: Shared VRAM: 1711276032
05:40:15.173: output 1: pos={0, 0}, size={1366, 768}, attached=true
05:40:15.211: Loading up D3D11 on adapter Intel(R) HD Graphics 3000 (0)
05:40:15.216: D3D11 loaded successfully, feature level used: 41216
05:40:22.125: ---------------------------------
05:40:22.125: video settings reset:
05:40:22.125: base resolution: 1366x768
05:40:22.125: output resolution: 1092x614
05:40:22.125: downscale filter: Bicubic
05:40:22.125: fps: 30/1
05:40:22.125: format: NV12
05:40:22.125: YUV mode: 601/Partial
05:40:22.222: Audio monitoring device:
05:40:22.222: name: Default
05:40:22.222: id: default
05:40:22.252: ---------------------------------
05:40:22.933: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
05:40:23.189: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
05:40:24.356: [AMF] AMF Test failed due to one or more errors.
05:40:24.356: Failed to initialize module 'enc-amf.dll'
05:40:33.079: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
05:40:33.155: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
05:40:33.155: (127)
05:40:33.155: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
05:40:33.618: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
05:40:34.389: [browser_source: 'Version: 1.31.0']
05:40:37.162: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
05:40:37.162: (126)
05:40:43.933: [obs-websocket] you can haz websockets (version 4.2.0)
05:40:43.933: [obs-websocket] qt version (compile-time): 5.7.0 ; qt version (run-time): 5.10.1
did anyone know this problem? anyway, thanks inb4
