Question / Help Personal Quality suggestions?
CREΛTOR
So I have seen tutorials and suggestion threads all over the place for OBS and how to get greater quality. My thing is no matter how much I play with my settings it doesn't improve. So I'm figuring it might be best to get suggestions based on my personal specs. I want to stream and record (not at the same time) in 1080p60fps or 720p60fps my capture card feed (I don't usually stream PC games). I'm able to do it it's just I want my image to be as crisp and clear as possible. Even if it means dropping down settings or upgrading my a bit. Another thing is I need to record my audio tracks separately so the simple mode no longer works for me. If you guys can make any tips or suggestions please let me know. Even rig upgrade suggestions because I can update my rig after the summer, but only if it is necessary. I'm on a budget.
RAM: 32GB (Memory Speed 1866 MHz)
CPU: AMD FX-Series Six-Core FX-6120 (3.5 GHz)
GPU: Nvidia Geforce GTX 1050ti 4GB
OS: Windows 10
Need any more details let me know.
