Y yakakgastrobaiter New Member Feb 3, 2020 #1 It is important that your program has the ability to transfer video to several sites at once, we can sign a petition for this.
T Tarumes Member Feb 3, 2020 #2 you can use nginx-rtmp for this Direct link to guide or search in Resources easy to setup easy to config you can monitor your stream live you can push to multiple sites at once you have extra statisic about used bandwith etc... you can host your own stream webpage
Narcogen Active Member Feb 3, 2020 #3 If you don't want to set up NGINX yourself, this is pretty much what restream.io does.
