I have a built in card reader, recorded to a 40MB/s SD card. SD card is formatted as FAT32 so 4GB max file size. Format your card to NTFS for files larger than 4GB.
23:29:02.724: [obs-nvenc: 'advanced_video_recording'] settings:
23:29:02.724: codec: HEVC
23:29:02.724: rate_control: CQP
23:29:02.724: bitrate: 0
23:29:02.724: cqp: 15
23:29:02.724: keyint: 60
23:29:02.724: preset: p6
23:29:02.724: tuning: hq
23:29:02.724: multipass: qres
23:29:02.724: profile: main
23:29:02.724: width: 1920
23:29:02.724: height: 1080
23:29:02.724: b-frames: 0
23:29:02.724: lookahead: false
23:29:02.724: psycho_aq: false
23:29:02.724:
23:29:02.767: ---------------------------------
23:29:02.767: [FFmpeg pcm_s24le encoder: 'Track1'] bitrate: 0, channels: 2, channel_layout: stereo
23:29:02.767:
23:29:02.783: ==== Recording Start ===============================================
23:29:02.783: [ffmpeg muxer: 'adv_file_output'] Writing file 'T:/Test/2024-03-07_23-29-02.mov'...
23:31:04.522: [ffmpeg muxer: 'adv_file_output'] Output of file 'T:/Test/2024-03-07_23-29-02.mov' stopped
23:31:04.522: Output 'adv_file_output': stopping
23:31:04.522: Output 'adv_file_output': Total frames output: 7266
23:31:04.522: Output 'adv_file_output': Total drawn frames: 7304
23:31:04.522: ==== Recording Stop ================================================
General | |
| Complete name : | T:\Test\2024-03-07_23-29-02.mov |
| Format : | MPEG-4 |
| Format profile : | QuickTime |
| Codec ID : | qt 0000.02 (qt ) |
| File size : | 400 MiB |
| Duration : | 2 min 1 s |
| Overall bit rate : | 27.7 Mb/s |
| Frame rate : | 60.000 FPS |
| Writing application : | Lavf60.3.100 |
Video | |
| ID : | 1 |
| Format : | HEVC |
| Format/Info : | High Efficiency Video Coding |
| Format profile : | [email protected]@Main |
| Codec ID : | hev1 |
| Codec ID/Info : | High Efficiency Video Coding |
| Bit rate : | 25.4 Mb/s |
| Width : | 1 920 pixels |
| Height : | 1 080 pixels |
| Display aspect ratio : | 16:9 |
| Frame rate mode : | Constant |
| Color space : | YUV |
| Chroma subsampling : | 4:2:0 |
| Bit depth : | 8 bits |
| Bits/(Pixel*Frame) : | 0.204 |
| Stream size : | 367 MiB (92%) |
| Color range : | Limited |
| Color primaries : | BT.709 |
| Transfer characteristics : | BT.709 |
| Matrix coefficients : | BT.709 |
| Codec configuration box : | hvcC |
Audio | |
| ID : | 2 |
| Format : | PCM |
| Format settings : | Little / Signed |
| Codec ID : | in24 |
| Bit rate mode : | Constant |
| Bit rate : | 2 304 kb/s |
| Channel(s) : | 2 channels |
| Channel layout : | L R |
| Sampling rate : | 48.0 kHz |
| Bit depth : | 24 bits |
| Stream size : | 33.3 MiB (8%) |
| Title : | Track1 |
| Default : | Yes |
| Alternate group : | 1 |
