Question / Help Recorded video is chopped (see screenshot)
Arnvlm
not %100 sure but it only seems to do this in-game. I thought this would be a common problem but I haven't seen anyone else who has had this happen to them as well.
Thats it? dang, well thanks man! also do I need a video editing program to be able to hear both of my audio tracks. Mic and game volume?
If you're recording them to separate audio tracks in the recording, you would need to merge them to hear both at once.
Also, we STRONGLY do NOT recommend saving directly to mp4.
I'm not sure how im recording i think its 2 audio tracks, how do i check? And also what format should I save in?
I dont really want to have separate audio tracks, right now anyways, how do I just make them into one? do I still use mkv then?
No, you can use FLV or MKV for single track
Switch your output mode to simple and make sure that all audio devices are enabled on all audio tracks in edit - advanced audio properties
ok so i just have game capure on, however, there is just a black bar where the second screen was on the top and everything is moved down so you cant see the bottom of the recorded gameplay.
