Bug Report Replay Buffer doesn't work.
Brokoth
I have been trying to use the replay buffer, with these recording settings:
  • Recording Format: mkv
  • Encoder: x264
  • Rate Control: CRF
  • CRF: 14
  • Keyframe Interval: 0
  • CPU Usage Preset: veryfast
However, it doesn't even save the clip in the first place. Before, i had used CBR as my Rate Control setting but with this the recording takes one minute plus to MAYBE record and even then, the recording is bugged.
How can i fix this?
My nvidia drivers and windows are completely up to date.
