Stream/recording quality worsens noticeably when game is in foreground(Dual PC Setup, All Common Fixes Tried)
FYI, from your last log. It appears that OBS may have been open when you changed the refresh rates. OBS should always be closed when making system changes. Still a mixed bag of Rendering Lag & Dropped Frames.
22:15:53.727: name=MSI G255F
22:15:53.727: pos={0, 0}
22:15:53.727: size={1920, 1080}
22:15:53.727: attached=true
22:15:53.727: refresh=180
22:15:53.727: bits_per_color=8
22:15:53.727: space=RGB_FULL_G22_NONE_P709
I uploaded a couple of videos you can use for testing. 60 & 120 FPS, perfectly timed, no skipped or duplicate frames.
i just tried streaking on kick at 8k bitrate and i dont have the problem there
i don't understand how i'm able to stream on a diffrent platform and it's better than when i even record on my pc i'm so confused
i also forgot to mention when i tested recordings with way higher bitrate i dont have the pixelation issue at all i don't know if that matter or not since twitch has a max of 6k bitrates anyway
