Question / Help Video Audio quality bad
MurayTheFloox
Since no one has encountered this issue obviously since i spent 2 hours searching for a fix yet only found MICROPHONE related and not GAME AUDIO related
Im getting this open air sound... was not like this yesterday. Everything is off, no surround, nothing. All enhancements off. I tried everything and just wont work. Im using an RTX 2080 Ti to encode and my settings are up to its highest
Heres a link to a video i posted
https://twitter.com/AbnormalBuilder/status/1233224402793377792?s=20
I just cant find a fix because the audio quality just stays the same.
Note My microphone is off and game audio is feeding through my system and it sounds like its all recorded with the microphone
21:50:48.473: CPU Name: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
21:50:48.473: CPU Speed: 3600MHz
21:50:48.473: Physical Cores: 8, Logical Cores: 16
21:50:48.473: Physical Memory: 32685MB Total, 24310MB Free
21:50:48.473: Windows Version: 10.0 Build 18362 (revision: 657; 64-bit)
21:50:48.473: Running as administrator: false
21:50:48.474: Aero is Enabled (Aero is always on for windows 8 and above)
21:50:48.474: Windows 10 Gaming Features:
21:50:48.474: Game DVR: On
21:50:48.475: Sec. Software Status:
21:50:48.475: Malwarebytes: disabled (AV)
21:50:48.476: Windows Defender Antivirus: enabled (AV)
21:50:48.476: Norton Security: disabled (AV)
21:50:48.476: Norton Security: enabled (FW)
21:50:48.476: Windows Firewall: enabled (FW)
21:50:48.476: Current Date/Time: 2020-02-27, 21:50:48
21:50:48.476: Browser Hardware Acceleration: true
21:50:48.476: Portable mode: false
21:50:48.632: OBS 24.0.3 (64-bit, windows)
21:50:48.632: ---------------------------------
21:50:48.633: ---------------------------------
21:50:48.633: audio settings reset:
21:50:48.633: samples per sec: 48000
21:50:48.633: speakers: 2
21:50:48.634: ---------------------------------
21:50:48.634: Initializing D3D11...
21:50:48.634: Available Video Adapters:
21:50:48.636: Adapter 0: NVIDIA GeForce RTX 2080 Ti
21:50:48.636: Dedicated VRAM: 2995781632
21:50:48.636: Shared VRAM: 4251676672
21:50:48.636: output 0: pos={0, 0}, size={1920, 1080}, attached=true
21:50:48.637: Loading up D3D11 on adapter NVIDIA GeForce RTX 2080 Ti (0)
21:50:48.673: D3D11 loaded successfully, feature level used: b000
21:50:48.673: D3D11 GPU priority setup failed (not admin?)
21:50:49.012: ---------------------------------
21:50:49.012: video settings reset:
21:50:49.012: base resolution: 1920x1080
21:50:49.012: output resolution: 1920x1080
21:50:49.012: downscale filter: Lanczos
21:50:49.012: fps: 60/1
21:50:49.012: format: NV12
21:50:49.012: YUV mode: 601/Partial
21:50:49.012: NV12 texture support enabled
21:50:49.013: Audio monitoring device:
21:50:49.013: name: Speakers (Realtek(R) Audio)
21:50:49.013: id: {0.0.0.00000000}.{37b2e6a2-0cae-4244-be54-eef8ce500592}
21:50:49.013: ---------------------------------
21:50:49.015: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
21:50:49.015: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
21:50:49.097: [AMF] AMF Test failed due to one or more errors.
21:50:49.097: Failed to initialize module 'enc-amf.dll'
21:50:49.108: [obs-browser]: Version 2.7.15
21:50:49.110: NVENC supported
21:50:49.159: Couldn't find VLC installation, VLC video source disabled
21:50:49.162: No blackmagic support
21:50:49.165: ---------------------------------
21:50:49.165: Loaded Modules:
21:50:49.165: win-wasapi.dll
21:50:49.165: win-mf.dll
21:50:49.165: win-dshow.dll
21:50:49.165: win-decklink.dll
21:50:49.165: win-capture.dll
21:50:49.165: vlc-video.dll
21:50:49.165: text-freetype2.dll
21:50:49.165: rtmp-services.dll
21:50:49.165: obs-x264.dll
21:50:49.165: obs-vst.dll
21:50:49.165: obs-transitions.dll
21:50:49.165: obs-text.dll
21:50:49.165: obs-qsv11.dll
21:50:49.165: obs-outputs.dll
21:50:49.165: obs-filters.dll
21:50:49.165: obs-ffmpeg.dll
21:50:49.165: obs-browser.dll
21:50:49.165: image-source.dll
21:50:49.165: frontend-tools.dll
21:50:49.165: enc-amf.dll
21:50:49.165: decklink-ouput-ui.dll
21:50:49.165: coreaudio-encoder.dll
21:50:49.165: ==== Startup complete ===============================================
21:50:49.167: All scene data cleared
21:50:49.167: ------------------------------------------------
21:50:49.301: WASAPI: Device 'Realtek Digital Output (Realtek(R) Audio)' initialized
21:50:49.330: WASAPI: Device 'Microphone (BWA19HO011)' initialized
21:50:49.362: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Mic/Aux)
21:50:49.362:
21:50:50.194: [window-capture: 'Window Capture 2'] update settings:
21:50:50.194: executable: PaintDotNet.exe
21:50:50.194: Switched to scene 'Scene'
21:50:50.195: [game-capture: 'Game Capture'] attempting to hook process: aces.exe
21:50:50.197: ------------------------------------------------
21:50:50.197: Loaded scenes:
21:50:50.197: - scene 'Scene':
21:50:50.197: - source: 'Game Capture' (game_capture)
21:50:50.197: - scene 'Scene 2':
21:50:50.197: - source: 'Window Capture 2' (window_capture)
21:50:50.198: [game-capture: 'Game Capture'] shared texture capture successful
21:50:51.565: [jim-nvenc: 'simple_h264_stream'] settings:
21:50:51.565: rate_control: CBR
21:50:51.565: bitrate: 3500
21:50:51.565: cqp: 20
21:50:51.565: keyint: 120
21:50:51.565: preset: mq
21:50:51.565: profile: high
21:50:51.565: width: 1920
21:50:51.565: height: 1080
21:50:51.565: 2-pass: true
21:50:51.565: b-frames: 2
21:50:51.565: lookahead: false
21:50:51.565: psycho_aq: true
21:50:51.565:
21:50:51.574: ---------------------------------
21:50:51.574: [FFmpeg aac encoder: 'simple_aac'] bitrate: 160, channels: 2, channel_layout: 3
21:50:51.574:
21:50:51.610: ==== Recording Start ===============================================
21:50:51.610: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/Tylor Holmes/Videos/2020-02-27 21-50-51.mov'...
21:51:02.369: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/Tylor Holmes/Videos/2020-02-27 21-50-51.mov' stopped
21:51:02.369: Output 'simple_file_output': stopping
21:51:02.369: Output 'simple_file_output': Total frames output: 637
21:51:02.369: Output 'simple_file_output': Total drawn frames: 646
21:51:02.369: ==== Recording Stop ================================================
21:52:34.977: Device 'Realtek Digital Output (Realtek(R) Audio)' invalidated. Retrying
21:52:38.079: WASAPI: Device 'Realtek Digital Output (Realtek(R) Audio)' initialized
21:54:07.108: [jim-nvenc: 'simple_h264_stream'] settings:
21:54:07.108: rate_control: CBR
21:54:07.108: bitrate: 3500
21:54:07.108: cqp: 20
21:54:07.108: keyint: 120
21:54:07.108: preset: mq
21:54:07.108: profile: high
21:54:07.108: width: 1920
21:54:07.108: height: 1080
21:54:07.108: 2-pass: true
21:54:07.108: b-frames: 2
21:54:07.108: lookahead: false
21:54:07.108: psycho_aq: true
21:54:07.108:
21:54:07.116: ---------------------------------
21:54:07.116: [FFmpeg aac encoder: 'simple_aac'] bitrate: 160, channels: 2, channel_layout: 3
21:54:07.116:
21:54:07.152: ==== Recording Start ===============================================
21:54:07.152: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/Tylor Holmes/Videos/2020-02-27 21-54-07.mov'...
21:54:19.549: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/Tylor Holmes/Videos/2020-02-27 21-54-07.mov' stopped
21:54:19.549: Output 'simple_file_output': stopping
21:54:19.549: Output 'simple_file_output': Total frames output: 735
21:54:19.549: Output 'simple_file_output': Total drawn frames: 744
21:54:19.550: ==== Recording Stop ================================================
21:54:51.587: WASAPI: Device 'Realtek Digital Output (Realtek(R) Audio)' Terminated
21:54:51.636: WASAPI: Device 'Speakers (Realtek(R) Audio)' initialized
21:54:51.644: Settings changed (audio)
21:54:51.644: ------------------------------------------------
21:55:16.547: [jim-nvenc: 'simple_h264_stream'] settings:
21:55:16.547: rate_control: CBR
21:55:16.547: bitrate: 3500
21:55:16.547: cqp: 20
21:55:16.547: keyint: 120
21:55:16.547: preset: mq
21:55:16.547: profile: high
21:55:16.547: width: 1920
21:55:16.547: height: 1080
21:55:16.547: 2-pass: true
21:55:16.547: b-frames: 2
21:55:16.547: lookahead: false
21:55:16.547: psycho_aq: true
21:55:16.547:
21:55:16.556: ---------------------------------
21:55:16.557: [FFmpeg aac encoder: 'simple_aac'] bitrate: 160, channels: 2, channel_layout: 3
21:55:16.557:
21:55:16.592: ==== Recording Start ===============================================
21:55:16.592: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/Tylor Holmes/Videos/2020-02-27 21-55-16.mov'...
21:55:27.352: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/Tylor Holmes/Videos/2020-02-27 21-55-16.mov' stopped
21:55:27.352: Output 'simple_file_output': stopping
21:55:27.352: Output 'simple_file_output': Total frames output: 637
21:55:27.352: Output 'simple_file_output': Total drawn frames: 646
21:55:27.352: ==== Recording Stop ================================================
21:58:43.230: ---------------------------------
21:58:43.230: video settings reset:
21:58:43.230: base resolution: 1920x1080
21:58:43.230: output resolution: 1920x1080
21:58:43.230: downscale filter: Lanczos
21:58:43.230: fps: 60/1
21:58:43.230: format: NV12
21:58:43.230: YUV mode: 601/Partial
21:58:43.230: NV12 texture support enabled
21:58:43.236: Settings changed (advanced)
21:58:43.236: ------------------------------------------------
21:59:01.202: Settings changed (outputs)
21:59:01.203: ------------------------------------------------
21:59:02.962: [jim-nvenc: 'simple_h264_stream'] settings:
21:59:02.962: rate_control: CBR
21:59:02.962: bitrate: 3500
21:59:02.962: cqp: 20
21:59:02.962: keyint: 120
21:59:02.962: preset: mq
21:59:02.962: profile: high
21:59:02.962: width: 1920
21:59:02.962: height: 1080
21:59:02.962: 2-pass: true
21:59:02.962: b-frames: 2
21:59:02.962: lookahead: false
21:59:02.962: psycho_aq: true
21:59:02.962:
21:59:02.972: ---------------------------------
21:59:02.972: [FFmpeg aac encoder: 'simple_aac'] bitrate: 320, channels: 2, channel_layout: 3
21:59:02.972:
21:59:03.009: ==== Recording Start ===============================================
21:59:03.009: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/Tylor Holmes/Videos/2020-02-27 21-59-02.mov'...
21:59:12.154: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/Tylor Holmes/Videos/2020-02-27 21-59-02.mov' stopped
21:59:12.154: Output 'simple_file_output': stopping
21:59:12.154: Output 'simple_file_output': Total frames output: 540
21:59:12.154: Output 'simple_file_output': Total drawn frames: 549
21:59:12.154: ==== Recording Stop ================================================
22:01:08.059: Settings changed (outputs)
22:01:08.059: ------------------------------------------------
22:01:10.275: [jim-nvenc: 'simple_h264_recording'] settings:
22:01:10.275: rate_control: CQP
22:01:10.275: bitrate: 0
22:01:10.275: cqp: 23
22:01:10.275: keyint: 250
22:01:10.275: preset: hq
22:01:10.275: profile: high
22:01:10.275: width: 1920
22:01:10.275: height: 1080
22:01:10.275: 2-pass: false
22:01:10.275: b-frames: 2
22:01:10.275: lookahead: false
22:01:10.275: psycho_aq: true
22:01:10.275:
22:01:10.285: ---------------------------------
22:01:10.285: [FFmpeg aac encoder: 'simple_aac_recording'] bitrate: 128, channels: 2, channel_layout: 3
22:01:10.285:
22:01:10.320: ==== Recording Start ===============================================
22:01:10.320: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/Tylor Holmes/Videos/2020-02-27 22-01-10.mp4'...
22:01:22.537: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/Tylor Holmes/Videos/2020-02-27 22-01-10.mp4' stopped
22:01:22.537: Output 'simple_file_output': stopping
22:01:22.537: Output 'simple_file_output': Total frames output: 724
22:01:22.537: Output 'simple_file_output': Total drawn frames: 733
22:01:22.538: ==== Recording Stop ================================================
22:07:30.911: [jim-nvenc: 'simple_h264_recording'] settings:
22:07:30.911: rate_control: CQP
22:07:30.911: bitrate: 0
22:07:30.911: cqp: 23
22:07:30.911: keyint: 250
22:07:30.911: preset: hq
22:07:30.911: profile: high
22:07:30.911: width: 1920
22:07:30.911: height: 1080
22:07:30.911: 2-pass: false
22:07:30.911: b-frames: 2
22:07:30.911: lookahead: false
22:07:30.911: psycho_aq: true
22:07:30.911:
22:07:30.920: ---------------------------------
22:07:30.920: [FFmpeg aac encoder: 'simple_aac_recording'] bitrate: 128, channels: 2, channel_layout: 3
22:07:30.920:
22:07:30.960: ==== Recording Start ===============================================
22:07:30.960: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/Tylor Holmes/Videos/2020-02-27 22-07-30.mp4'...
22:07:39.529: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/Tylor Holmes/Videos/2020-02-27 22-07-30.mp4' stopped
22:07:39.529: Output 'simple_file_output': stopping
22:07:39.529: Output 'simple_file_output': Total frames output: 506
22:07:39.529: Output 'simple_file_output': Total drawn frames: 514
22:07:39.530: ==== Recording Stop ================================================
22:08:30.637: Settings changed (outputs)
22:08:30.637: ------------------------------------------------
22:08:48.544: Settings changed (outputs)
22:08:48.544: ------------------------------------------------
22:08:50.090: ==== Recording Start ===============================================
22:09:00.165: Output 'simple_ffmpeg_output': stopping
22:09:00.165: Output 'simple_ffmpeg_output': Total frames output: 604
22:09:00.165: Output 'simple_ffmpeg_output': Total drawn frames: 605
22:09:00.166: ==== Recording Stop ================================================
When was the last time you updated your Realtek drivers?
What changed on your system in software/updates between yesterday and today? Windows update?
Go to you motherboard manufacturer and update the audio drivers.
You are better off getting an audio interface box like Focusrite Scarlett or Presonus AudioBox. You have a nice i9-9900K and RTX 2080Ti like I do but you can do way better with audio. Go a step higher and you will be able to improve your audio experience with better headphones and mics. I never use onboard audio because, well, its not very good...
