Question / Help Video lagging altho nothing is wrong really
Mahiru
I used to record normally and everything was fine until today, I started recording just as I normally do and when I looked at the file afterwards it was hella laggy... Ill attach my settings
17:02:22.220: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
17:02:22.220: CPU Speed: 3293MHz
17:02:22.220: Physical Cores: 4, Logical Cores: 4
17:02:22.220: Physical Memory: 8157MB Total, 2498MB Free
17:02:22.220: Windows Version: 10.0 Build 17763 (revision: 437; 64-bit)
17:02:22.220: Running as administrator: false
17:02:22.220: Aero is Enabled (Aero is always on for windows 8 and above)
17:02:22.220: Windows 10 Gaming Features:
17:02:22.220: Game Bar: Off
17:02:22.220: Game DVR: Off
17:02:22.220: Game DVR Background Recording: Off
17:02:22.220: Game Mode: Off
17:02:22.223: Sec. Software Status:
17:02:22.226: Windows Defender Antivirus: enabled (AV)
17:02:22.227: Windows Firewall: enabled (FW)
17:02:22.228: Windows Defender Antivirus: enabled (ASW)
17:02:22.239: Current Date/Time: 2019-04-28, 17:02:22
17:02:22.239: Browser Hardware Acceleration: true
17:02:22.239: Portable mode: false
17:02:23.729: OBS 23.1.0 (64-bit, windows)
17:02:23.729: ---------------------------------
17:02:23.730: ---------------------------------
17:02:23.730: audio settings reset:
17:02:23.730: samples per sec: 44100
17:02:23.730: speakers: 2
17:02:23.764: ---------------------------------
17:02:23.764: Initializing D3D11...
17:02:23.764: Available Video Adapters:
17:02:23.767: Adapter 1: NVIDIA GeForce GTX 960
17:02:23.767: Dedicated VRAM: 4250206208
17:02:23.767: Shared VRAM: 4277082112
17:02:23.767: output 1: pos={0, 0}, size={1920, 1080}, attached=true
17:02:23.770: Loading up D3D11 on adapter NVIDIA GeForce GTX 960 (0)
17:02:23.863: D3D11 loaded successfully, feature level used: 45056
17:02:25.362: ---------------------------------
17:02:25.362: video settings reset:
17:02:25.362: base resolution: 1920x1080
17:02:25.362: output resolution: 1920x1080
17:02:25.362: downscale filter: Lanczos
17:02:25.362: fps: 180/1
17:02:25.362: format: NV12
17:02:25.362: YUV mode: 601/Partial
17:02:25.364: NV12 texture support enabled
17:02:25.374: Audio monitoring device:
17:02:25.374: name: Standard
17:02:25.374: id: default
17:02:25.375: ---------------------------------
17:02:25.569: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
17:02:25.621: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
17:02:25.851: [AMF] AMF Test failed due to one or more errors.
17:02:25.852: Failed to initialize module 'enc-amf.dll'
17:02:26.733: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
17:02:26.936: [obs-browser]: Version 2.3.1
17:02:27.269: NVENC supported
17:02:28.175: Couldn't find VLC installation, VLC video source disabled
17:02:28.333: No blackmagic support
17:02:28.526: ---------------------------------
17:02:28.526: Loaded Modules:
17:02:28.526: win-wasapi.dll
17:02:28.526: win-mf.dll
17:02:28.526: win-dshow.dll
17:02:28.526: win-decklink.dll
17:02:28.526: win-capture.dll
17:02:28.526: vlc-video.dll
17:02:28.526: text-freetype2.dll
17:02:28.526: rtmp-services.dll
17:02:28.526: obs-x264.dll
17:02:28.526: obs-vst.dll
17:02:28.526: obs-transitions.dll
17:02:28.526: obs-text.dll
17:02:28.526: obs-qsv11.dll
17:02:28.526: obs-outputs.dll
17:02:28.526: obs-filters.dll
17:02:28.526: obs-ffmpeg.dll
17:02:28.526: obs-browser.dll
17:02:28.526: image-source.dll
17:02:28.526: frontend-tools.dll
17:02:28.526: enc-amf.dll
17:02:28.526: decklink-ouput-ui.dll
17:02:28.526: coreaudio-encoder.dll
17:02:28.526: ==== Startup complete ===============================================
17:02:28.570: Service '' not found
17:02:28.676: All scene data cleared
17:02:28.676: ------------------------------------------------
17:02:28.827: WASAPI: Device 'Lautsprecher (3- Logitech G430 Gaming Headset)' initialized
17:02:28.892: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds (source: Desktop Audio)
17:02:28.892:
17:02:28.992: WASAPI: Device 'Mikrofon (Voicemod Virtual Audio Device (WDM))' initialized
17:02:28.997: Switched to scene 'Szene'
17:02:29.028: ------------------------------------------------
17:02:29.028: Loaded scenes:
17:02:29.028: - scene 'Szene':
17:02:29.028: - source: 'Bildschirmaufnahme' (monitor_capture)
17:02:29.063: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux)
17:02:29.063:
17:02:38.015: ---------------------------------
17:02:38.015: video settings reset:
17:02:38.015: base resolution: 1920x1080
17:02:38.015: output resolution: 1920x1080
17:02:38.015: downscale filter: Lanczos
17:02:38.015: fps: 30/1
17:02:38.015: format: NV12
17:02:38.015: YUV mode: 601/Partial
17:02:38.015: NV12 texture support enabled
17:02:38.036: Settings changed (video)
17:02:38.036: ------------------------------------------------
17:02:39.111: [jim-nvenc: 'recording_h264'] settings:
17:02:39.111: rate_control: CBR
17:02:39.111: bitrate: 80000
17:02:39.111: cqp: 20
17:02:39.111: keyint: 250
17:02:39.111: preset: hp
17:02:39.111: profile: high
17:02:39.111: width: 1920
17:02:39.111: height: 1080
17:02:39.111: 2-pass: false
17:02:39.111: b-frames: 2
17:02:39.111: lookahead: false
17:02:39.111: psycho_aq: false
17:02:39.111:
17:02:39.132: ---------------------------------
17:02:39.166: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 2, channel_layout: 3
17:02:39.166:
17:02:39.252: ==== Recording Start ===============================================
17:02:39.252: [ffmpeg muxer: 'adv_file_output'] Writing file 'D:/Videos/2019-04-28 17-02-39.mp4'...
17:03:35.813: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds (source: Mic/Aux)
17:03:35.813:
17:03:39.813: adding 23 milliseconds of audio buffering, total audio buffering is now 92 milliseconds (source: Mic/Aux)
17:03:39.813:
17:03:40.062: [ffmpeg muxer: 'adv_file_output'] Output of file 'D:/Videos/2019-04-28 17-02-39.mp4' stopped
17:03:40.062: Output 'adv_file_output': stopping
17:03:40.062: Output 'adv_file_output': Total frames output: 1806
17:03:40.062: Output 'adv_file_output': Total drawn frames: 1795 (1825 attempted)
17:03:40.062: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 30 (1.6%)
17:03:40.062: ==== Recording Stop ================================================
17:03:40.074: Video stopped, number of skipped frames due to encoding lag: 34/1821 (1.9%)
17:05:55.577: ==== Shutting down ==================================================
17:05:55.617: Switched to scene '(null)'
17:05:55.617: WASAPI: Device 'Lautsprecher (3- Logitech G430 Gaming Headset)' Terminated
17:05:55.637: WASAPI: Device 'Mikrofon (Voicemod Virtual Audio Device (WDM))' Terminated
17:05:55.649: All scene data cleared
17:05:55.649: ------------------------------------------------
17:05:55.875: Freeing OBS context data
17:05:56.006: [Scripting] Total detached callbacks: 0
17:05:56.109: == Profiler Results =============================
17:05:56.109: run_program_init: 8049.32 ms
17:05:56.109: ┣OBSApp::AppInit: 127.197 ms
17:05:56.109: ┃ ┗OBSApp::InitLocale: 55.437 ms
17:05:56.109: ┗OBSApp::OBSInit: 7214.86 ms
17:05:56.109: ┣obs_startup: 19.892 ms
17:05:56.109: ┗OBSBasic::OBSInit: 5704.63 ms
17:05:56.109: ┣OBSBasic::InitBasicConfig: 0.513 ms
17:05:56.109: ┣OBSBasic::ResetAudio: 1.467 ms
17:05:56.109: ┣OBSBasic::ResetVideo: 1643.07 ms
17:05:56.109: ┣OBSBasic::InitOBSCallbacks: 0.012 ms
17:05:56.109: ┣OBSBasic::InitHotkeys: 0.917 ms
17:05:56.109: ┣obs_load_all_modules: 3151.03 ms
17:05:56.109: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.788 ms
17:05:56.109: ┃ ┣obs_init_module(decklink-ouput-ui.dll): 24.408 ms
17:05:56.109: ┃ ┣obs_init_module(enc-amf.dll): 137.835 ms
17:05:56.110: ┃ ┣obs_init_module(frontend-tools.dll): 83.921 ms
17:05:56.110: ┃ ┣obs_init_module(image-source.dll): 0.006 ms
17:05:56.110: ┃ ┣obs_init_module(obs-browser.dll): 27.164 ms
17:05:56.110: ┃ ┣obs_init_module(obs-ffmpeg.dll): 96.221 ms
17:05:56.110: ┃ ┃ ┗nvenc_check: 80.153 ms
17:05:56.110: ┃ ┣obs_init_module(obs-filters.dll): 0.038 ms
17:05:56.110: ┃ ┣obs_init_module(obs-outputs.dll): 13.808 ms
17:05:56.110: ┃ ┣obs_init_module(obs-qsv11.dll): 85.817 ms
17:05:56.110: ┃ ┣obs_init_module(obs-text.dll): 0.321 ms
17:05:56.110: ┃ ┣obs_init_module(obs-transitions.dll): 0.01 ms
17:05:56.110: ┃ ┣obs_init_module(obs-vst.dll): 0.003 ms
17:05:56.110: ┃ ┣obs_init_module(obs-x264.dll): 0.003 ms
17:05:56.110: ┃ ┣obs_init_module(rtmp-services.dll): 1.322 ms
17:05:56.110: ┃ ┣obs_init_module(text-freetype2.dll): 0.258 ms
17:05:56.110: ┃ ┣obs_init_module(vlc-video.dll): 0.063 ms
17:05:56.110: ┃ ┣obs_init_module(win-capture.dll): 0.144 ms
17:05:56.110: ┃ ┣obs_init_module(win-decklink.dll): 5.09 ms
17:05:56.110: ┃ ┣obs_init_module(win-dshow.dll): 11.509 ms
17:05:56.110: ┃ ┣obs_init_module(win-mf.dll): 0 ms
17:05:56.110: ┃ ┣obs_init_module(win-wasapi.dll): 0.018 ms
17:05:56.110: ┃ ┗reset_win32_symbol_paths: 1.018 ms
17:05:56.110: ┣OBSBasic::ResetOutputs: 37.415 ms
17:05:56.110: ┣OBSBasic::CreateHotkeys: 5.546 ms
17:05:56.110: ┣OBSBasic::InitService: 43.343 ms
17:05:56.110: ┣OBSBasic::InitPrimitives: 0.128 ms
17:05:56.110: ┗OBSBasic::Load: 447.024 ms
17:05:56.110: obs_hotkey_thread(25 ms): min=0.003 ms, median=0.007 ms, max=338.232 ms, 99th percentile=0.44 ms, 99.9745% below 25 ms
17:05:56.110: audio_thread(Audio): min=0 ms, median=0.094 ms, max=317.743 ms, 99th percentile=8.141 ms
17:05:56.110: ┗receive_audio: min=0.003 ms, median=0.916 ms, max=157.432 ms, 99th percentile=13.688 ms, 0.306972 calls per parent call
17:05:56.110: ┣buffer_audio: min=0.001 ms, median=0.002 ms, max=4.726 ms, 99th percentile=0.009 ms
17:05:56.110: ┗do_encode: min=0.339 ms, median=0.91 ms, max=157.427 ms, 99th percentile=13.684 ms
17:05:56.110: ┗encode(Track1): min=0.337 ms, median=0.633 ms, max=157.18 ms, 99th percentile=10.097 ms
17:05:56.110: obs_graphics_thread(5.55556 ms): min=0.049 ms, median=0.283 ms, max=31.23 ms, 99th percentile=3.144 ms, 99.6009% below 5.556 ms
17:05:56.110: ┣tick_sources: min=0.001 ms, median=0.077 ms, max=19.813 ms, 99th percentile=2.112 ms
17:05:56.110: ┣output_frame: min=0.047 ms, median=0.154 ms, max=31.212 ms, 99th percentile=2.274 ms
17:05:56.110: ┃ ┗gs_context(video->graphics): min=0.047 ms, median=0.153 ms, max=31.212 ms, 99th percentile=2.273 ms
17:05:56.110: ┃ ┣render_video: min=0.004 ms, median=0.043 ms, max=5.763 ms, 99th percentile=0.84 ms
17:05:56.110: ┃ ┃ ┗render_main_texture: min=0.003 ms, median=0.04 ms, max=3.576 ms, 99th percentile=0.7 ms
17:05:56.110: ┃ ┗gs_flush: min=0.042 ms, median=0.111 ms, max=12.058 ms, 99th percentile=1.047 ms
17:05:56.110: ┗render_displays: min=0.001 ms, median=0.001 ms, max=0.028 ms, 99th percentile=0.003 ms
17:05:56.110: OBSBasic::ResetVideo: 7.924 ms
17:05:56.110: obs_graphics_thread(33.3333 ms): min=0.11 ms, median=0.561 ms, max=330.548 ms, 99th percentile=13.32 ms, 99.729% below 33.333 ms
17:05:56.110: ┣tick_sources: min=0.004 ms, median=0.236 ms, max=329.516 ms, 99th percentile=6.027 ms
17:05:56.110: ┣output_frame: min=0.075 ms, median=0.209 ms, max=271.216 ms, 99th percentile=9.609 ms
17:05:56.110: ┃ ┗gs_context(video->graphics): min=0.075 ms, median=0.208 ms, max=271.215 ms, 99th percentile=9.608 ms
17:05:56.110: ┃ ┣render_video: min=0.011 ms, median=0.05 ms, max=162.864 ms, 99th percentile=6.483 ms
17:05:56.110: ┃ ┃ ┣render_main_texture: min=0.005 ms, median=0.041 ms, max=13.874 ms, 99th percentile=1.235 ms
17:05:56.110: ┃ ┃ ┣render_output_texture: min=0.001 ms, median=0.01 ms, max=24.899 ms, 99th percentile=0.336 ms, 0.30398 calls per parent call
17:05:56.110: ┃ ┃ ┣render_convert_texture_nv12: min=0 ms, median=0.02 ms, max=3.367 ms, 99th percentile=0.641 ms, 0.30398 calls per parent call
17:05:56.110: ┃ ┃ ┗output_gpu_encoders: min=0 ms, median=0.045 ms, max=161.159 ms, 99th percentile=5.948 ms, 0.30398 calls per parent call
17:05:56.110: ┃ ┗gs_flush: min=0.024 ms, median=0.107 ms, max=120.771 ms, 99th percentile=3.67 ms
17:05:56.110: ┗render_displays: min=0 ms, median=0.001 ms, max=0.992 ms, 99th percentile=0.029 ms
17:05:56.110: =================================================
17:05:56.110: == Profiler Time Between Calls ==================
17:05:56.110: obs_hotkey_thread(25 ms): min=24.168 ms, median=25.989 ms, max=362.902 ms, 18.2883% within ±2% of 25 ms (0.649516% lower, 81.0621% higher)
17:05:56.110: obs_graphics_thread(5.55556 ms): min=0.101 ms, median=5.556 ms, max=31.236 ms, 47.3381% within ±2% of 5.556 ms (26.7968% lower, 25.8651% higher)
17:05:56.110: obs_graphics_thread(33.3333 ms): min=0.351 ms, median=33.333 ms, max=330.553 ms, 49.729% within ±2% of 33.333 ms (25.1016% lower, 25.1694% higher)
17:05:56.560: Number of memory leaks: 0
Oh yeah heres the log aswell
