Question / Help XBOX lags on stream, 0 droppped frames on OBS
Code:
17:41:00.951: Loading up D3D11 on adapter Intel(R) HD Graphics 630 (0)
Run OBS on the GTX 1050 via NVIDIA Control Panel.
im not sure if im missing something but it says to use integrated graphics. unless im miss understanding.
  • NOTE: If you want to use Display Capture on a Laptop, set this to the Integrated Graphics Processor. This will mean that Window Capture and Game Capture will not work, and the performance of OBS Studio may be degraded.
ive been streaming for over a year and its been fine up to maybe the new update. im gonna try to stream with SLOBS tonight and see if theres a difference. i appreciate the help @OG See OH Zee
i appreciate your input, but how is it not an OBS issue when it worked fine previously, also works fine on SLOBS? im unable to capture the computer display when running OBS on NVIDIA. the only fix i have found for that was to run OBS on Intel.
